Tumirik ung sa opismate ko na crdi accent 2015 nung nakargahan sya ng gas. Nagpa gas sya p300 sa qc and tumirik sya somewhere in tplex.
Following day binalikan namin petron station and check sa cctv ung nangyari and pinakita ung resibo na nakalagay xcs naikarga instead turbo diesel. End of story, nareimburse nya ung cost ng tow amd fuel system cleaning ni casa.
Hirap icompromise ang makina.. Mahal na. . Abala pa..
Para sating lahat siguro. . Signages really helps..
Tao din mga gasoline boys natin. Pagod. . Problemada. . Puyat etc.
Balik sa topic.
Tama mga payo nila. Flash it out then put signage/sticker!
Have a safe day boss!
Sent from my LG-H818 using Tsikot Forums mobile app
You can check ur sales invoice makijita mo kung ano nakarga nila.
Sent from my SM-J700H using Tsikot Forums mobile app
the octane level of the fuel in your gas tank goes down. the worse that can happen is you rev the engine and it knocks. or there is more diesel than gasoline so the engine does not run at all.
first thing i'd do is to fill up to full tank to dilute that diesel. 2nd, add octane enhancer and stay in low revs (below 3k) until the next full tank.
or drain the tank tutal sabi mo 1/4 level na lang.
may oner type jeep ako dati RF mazda makina diesel.nakargahan din sa shell ng macapagal ng gasoline.wala pang 3 mins pumalya agad makina at parang nag wa wild..nung nakita ko resibo gasoline ung nilagay..pero may naka indicate ako dun sa bukasan ng tanke na diesel..sabi nung gasoline boy bihira daw kasi ung diesel sa oner type jeep ayun..tinanggal lahat ng laman at pinalitan nila kung gano karami ung laman ng tangke ganun din ung ipinalit..
Kung naging mas mausok na kulay puti ang buga ng tambutso mo kaysa dati then may diesel nga nahalo sa fuel mo.
Our old owner type jeep with 4K engine was once filled with diesel. The effect was immediate. Stuttering with really really thick emission.
With computer and sensors in current engines, I think if diesel was indeed put in the tank of a gasoline engine, you would have noticed it or the system will flash something.
Putting Petrol Into A Diesel Car #TBT - Fifth Gear - YouTube
Sent from Zenfone 3 on Tsikot mobile app
Baka namalik mata kalang TS, naramdaman muna dapat yan sa tinakbo mo. Happens to us long time ago sa petron naman, oner naman gas engine 4k kinargahan ng diesel. Mga 2kilometers palang tinakbo tumirik na eh,good thing mag malapit ma talyer kung saan tumirik. Pag open nila ng carburador amoy diesel, balik kami sa petron ayun deny to the bones ang gasoline boy which we forgot to take the receipt.haha
Drain lang ung tank ng oner and lininis ung line and carb and changed spark plug.
How did you confirm that you loaded diesel? If it's just because of the nozzle jacket, it's actually highly likely that they just mistakenly put a black jacket on a gasoline nozzle.
Gas and diesel nozzles are exactly the same, but if you're driving a sedan I don't think you'll get a misfill.
Most common misfill vehicles are Innovas, Tucsons, and Fortuners because all of them are offered in both gas and diesel variants.
