Hi sir tanong ko lang kasi mausok yung pickup ko Isuzu LS 1994 (medyo white/bluish) lalo na pag nag cchange gear / paakyat yung daan
Your car is 19 years old, with very high mileage probably.
- When do i change my piston rings & cylinder head gaskets?
If your car was well maintained and never experienced an overheat condition, it would probably need an overhaul every 250k kms. But please verify this with Isuzu.
ang sabi kasi ng mekaniko na nag calibrate ng makina ko (valve clearance & nozzle cleaning last 2011) kelangan ko daw magpalit nun.. kasi hindi pa rin nawala yung usok eh tapos may lumalabas na usok parang steam sa may dipstick. Possible yan dahil malakas na ang blowby ng engine.
- Kelangan ko ba ipa cleaning yung Injection pump or ipa adjust? - mahina humatak.. Walang magagawa ang cleaning or adjustment ng injection pump at injectors kung worn out na sila. The diesel injection system is as old as the car. Sa palagay ko, dapat ipa evaluate mo nang mabuti kung engine, or pump, or pareho sila ang dapat ma-overhaul.
kaka change oil ko lang last month (oil filter & air filter changed)
*can you pm me how much singil ng shop niyo for valve clearance tska nozzle cleaning pati check up?
Dalhin mo nalang sa Central for ocular inspection......no charge....
thanks sir
