Originally Posted by
Dieseldude
*Boss Dieseldude
Need your expert advice po. I recently bought a Foton Blizzard pick-up with 2.8L NA 4JB1 engine.
My experience as of the moment is steering wheel, pedals & shift knob vibrations during idle. My first diagnosis is cheap engine mounts and transmission mounts. Worry ko lang po kung masosolve nito ung vibrations na na-e-experience ko ngaun kung papalitan ko ung mga mounts. I don't know if vibration will be corrected by replacing engine mounts. I've never worked on a Foton. Btw, check the exhaust pipe if it has rubber isolator hangers.
My next concern is the loud engine noise na pasok sa loob ng cabin and parang nagp-produce pa siya ng low frequency noise na in long drives eh irritating na masyado. Any advice po to reduce the engine noise? Was planning to install sound deadeners sa hood and sa loob ng cabin to reduce noises. Install padding on the engine firewall if none. Retard engine timing by 1 or 2 degrees. It might reduce combustion noise.
Any advice po regarding my concerns will be greatly appreciated po.
thanks in advance
Roadstar is reliable.
Finding the Best Tire for You
