Quote Originally Posted by eugene emmanuel View Post
Helow mga sirs!
Newbie lang po sa tsikot. Pwede po makisali sa tread nato? interesting po kc.
have anyone heared of using "ferrocene" as fuel additive?
I'm planning kc of using this chemical for my 2.5L TDIC Pajero but were not sure of the possible effects on small automotive engines. baka may naka gamit na po sa inyo, pls share any results either positive or negative.
Actually we are using this chemical on marine diesel engines (as big as 24000bhp output) for almost 6 yrs and d results were very satisfactory, in terms of lessening engine carbon deposits, oil contamination and engine wear.
According to the instruction manual of this additive the following are the benefits of using this chemical:
1.decrease in exhaust temperature
2.decrease in adhesive carbon to exhaust valve, injector nozzle, piston ring and crown
3.decrease in smoke Bosch number from exhaust pipe
4.decrease in rate wear of piston ring and cylinder liner
5.decrease in dirt deposits in turbocharger turbine blades
6.decrease in lube oil carbon contamination
7.ensures complete burnout of carbon and hydrocarbon
this are some of the chemical specifications:
Chemical name: "ferrocene" Dicyclopentadienyliron
Chemical formula: (C5H5)2Fe
appearance: orange crystalline solid
application: combustion catalyst
CAS No. 102-54-5
also, according to the instruction manual, this chemical is should be mixed with fuel oil at 25ppm concentration in order to attain maximum effectiveness.. On board, we are mixing 1kg of ferrocene into 40 MT of fuel oil..
given the SG of diesel is 0.8796
40MT of diesel is 45500 ltrs
1000grams of ferrocene into 45500 ltrs of diesel oil
gives 0.02 grams of ferrocene/liter of diesel
which in the case of my pajero fuel tank of 92 liters capacity, in order for me to attain 25ppm effective concentration,
I only need to mix 1.8 grams of ferrocene per 1 full tank / 92 liters of my pajero.
1.8 grams per 92 liters of diesel oil, sulit po dba?!?
plus pa the benefits stipulated on the manual for using this chemical wich is listed above. sulit na sulit!!!
Anyway, hindi pa po ako nakagamit nito personally because on board pa po ako ngayon. I'll keep you informed regarding the results positive man or negative once i used this chemical/fuel additive on my own ride.
Any feedbacks, appreciated po.
More horsepower mga sirs!!!
God bless us all.
mga sirs, very sorry po for the late update regarding sa ferrocene try out ko...na delay po kc vessel disembarkation ko at pagbalik ng pinas, very busy pa...any way, heto na po result ng ferrocene on my 2.5L 4d56 TDIC M/T pajero..
*first run . without ferrocene
26 november 2010...0800H
filled up at guimbal, iloilo (autostop)
reset trip meter
travelled from guimbal to san joaquin, iloilo then back to guimbal.
re filled tank(autostop) at guimbal at the same gas station and the same pump.
consumed 3.656 liters of petron diesel max.. trip meter read 50.1 kms.
result at 13.7 kms/ltr
which is my normal hi-way driving fuel consumption...and i always get this fc even on previous years..on this route.
* second run . with 4 grams ferrocene mixed on my fuel tank of 92 liters capacity.
06 december 2010...0800H
reset trip meter
refilled tank(autostop) at guimbal at the same gas station and the same pump.
consumed 2.839 liters of petron diesel max (with ferrocene)..
result at 17.6 kms/ltr
which showed a 28.4 % increase in fuel mileage...
(this was at 50ppm ferrocene concentration at initial use..havent tried the 25 ppm concentration yet which the manual suggests on the following usage)
i'll keep you posted mga sirs...
Have googled this fuel additive and it seemed to be effective.
Ferox ang brand name for consumer users. Kaya lang wala pa yata dito sa pinas
