Page 2 of 6 FirstFirst 123456 LastLast
Results 11 to 20 of 51
    Jan 2008
    Quote Originally Posted by Noel Salisipan View Post
    Between 2-3yrs ang coolant lalo na kung high mileage.
    With that period kung hindi naman bababa sa minimum level ng reservoir yung coolant okey na na hindi mai-sakto sa high level.
    Replaced coolant of my 5 year old car. No significant dirt or rust found..
    Replaced coolant of my 18 year old car. Suprised that no rust or dirt found too.. even the main ports from the engine looks new!
    Never use water talaga sa cooling system to prevent rust formation
    10 years na ngayon ang mga bagong kotse, bago magpalit ng coolant. It should be written in your manual.
    Feb 2017
    Nakalagay po sa manual ko R eh. R= replace, wala sa manual refill kaya mejo ndi specific.
    Feb 2017
    E diba po pag nag flush ng coolant, ginagamitan ng pure distilled water hanggang luminis, edi masama pala yun po?
    Apr 2014
    Note:
    distilled water is generally good sa radiator
    Tap water and mineral water is bad.
    Yan ang difference ng water terms sa radiators.
    What car is that? *danegoesonline
    Sep 2016
    Ano po ba ang nilalagay sa loob ng radiator cap pag binuksan? Direct Coolant po ba or distilled water lang po ba?
    Quote Originally Posted by ReggieMar View Post
    distilled? thats for emergency use only. kalawang habol mo nyan...
    Sep 2016
    ok sir this is noted. diba meron na po coolant reservoir ang mga saaskyan kaylan ba dapat i-check ang radiator cap or no need na kasi meron reservoir? sorry po sobrang newbie po
    if you drain and fill... you fill and purge via radiator cap.
Coolant flush or refill?
