Page 2 of 4 FirstFirst 1234 LastLast
Results 21 to 40 of 66
    #21
    is there really a better way to avoid engine sludge or black death?
    correct me on this one, please; coz after reading this, I think this is what am gonna be doing:
    - change oil every 5k kms.
    - change oil filter (original Toyota Oil filter)
    - flush engine and let it run for 5-10 mins
    what is your idea about some mechanics, blowing some air using a compressor on the engine before they put the new oil, para daw matangal ang dumi at mga naiwan na residue? how reliable is this one....
    :car:
    #22
    Quote Originally Posted by ajOT View Post
    Pointless. And it might actually introduce water into the engine.
    Jun 2008
    #23
    worried na ko dito ah.. after watching this on youtube..
    [ame="http://www.youtube.com/watch?v=fs7WI2s-CVw"]YouTube- Toyota Engine Oil Sludge or Toyota Oil Gel Engine Failure[/ame]
    kakakuha ko pa naman lang ng '10 altis after painfully deciding bet. civic, mazda3, and altis.. i've always been a nissan and mitsubishi user and never had anything like this even if you miss on-time oil change..
    the guy on you tube said something about the design of the PCV (positive crankcase ventilation) being prone to causing this problem.. actually some frames they showed were not only sludge but coked oil sticking to most metal parts.. i guess once coking sets-in-- that's already the death of the engine.. even turbine engines-- once they get this they are sent for de-coking. otherwise, engine just stops or wont turn at all..
    sana naman corrected na yan sa mga bagong altis.. baka dito tinambak satin mga 'to ah!
    Jun 2007
    #24
    Quote Originally Posted by hy-n-dry View Post
    the current altis has the same engine from the pre-facelift version. so... watch out for sludge!
    Sep 2009
    #25
    Just change the oil following the severe maintenance sched and there should be no problems with sludging. Our daily driven 93 Corolla gets 4 oil changes a year and never had a sludging problem in 16 years.
    I've heard though, that interchanging between synthetic and mineral oil promotes sludging. It was never an issue for us though, because we always used the cheapest mineral oil. As long as scheduled ang palit ng langis, di problema yan.
    Mga kano kasi sobrang tamad magmaintain ng makina. Since they change cars every few years or so, I guess more often than not they feel there's no need to worry about maintenance. Lalo na pag leased yung kotse.
    Jan 2009
    #26
    This is an old issue with Toyota (and Lexus) cars. Frequent changes and owners diligently monitoring their cars are a must. Not just regular but diligent.
    I want a reliable and easy to use car not one which can easily have parts replaced often.
    So I also do not own a Toyota.
    #27
    i just see this actual a Toyota Altis not the new one when the mechanic open the valve cover you can see a sludge build up in the valve cover and rocker arm .I dont know if this is the sickness of Altis but for me if you want to prevent sludge change oil every 3,000 km or less .
    #28
    Quote Originally Posted by speed unlimited View Post
    aint that changing of engine oil and oil filter every 5k kms. driven not that enough to prevent this what they call a gelatin or sludge on the engine?
    Jun 2006
    #29
    every 3000km change oil? sheesh! that equates to at least 4 changeoil per year.
    heniway.. kasama ba 1tr engine dito?
    #30
    Exactly. Air compressor tanks contain a bit of water which builds up over time because of the pressure, humidity, etc. When I used to maintain our internet cafe before, I had to get a water filter -which looks like a motorcycle engine's fuel filter- clamped between the valve and the hose to hopefully separate the water from the air before I clean the cpu's.
    There were still tiny bits of water coming out so imagine if it didn't have that water filter.
    Dec 2009
    #31
    Magpapa 1k PMS ako next week, balak kong palitan ng synthetic oil yung dating mineral oil. Kelangan ko pa bang mag flush ng engine? TIA
    Jun 2008
    #32
    Hindi ako magtataka kung ang makina ay diesel engine pero sa toyota gasoline engine hindi normal ito. Akala ko pa naman sila ang mas advance sa technology sa mga japanese car maker.
    Ang alam ko isa sa mga dahilan ng sludge build-up ay ang poor combustion. Ang by-product ng combustion ay bumabagsak sa crankcase at hahalo sa langis.
    Jun 2008
    #33
    Ang alam ko isa sa mga dahilan ng sludge build-up ay ang poor combustion. Ang by-product ng combustion ay bumabagsak sa crankcase at hahalo sa langis. Kadalasan mangyayari ito kapag hindi maganda ang pagka "break-in" ng makina noong bago pa. Pwede rin ang quality ng piston rings ay hindi compatible sa material ng cylinder liner kaya hindi mag seat-in kaagad during short break-in period, pero after several thousand running hours when the piston rings attained the optimum tightness sa cylinder wall itong oil sludge build up ay ma neutralized.
    edited for additional input.
    Aug 2005
    #34
    Tumirik kahapon si Mrs sa SLEX, dala nya ang ZZ. napatow nya papunta sa mechaniko namin. Ng buksan ang makina. SLUDGE!
    Sorry camera from a phone ang gamit.
    DOHC ang makina. iyong exhaust cam hindi umiikot pag inis-start ang makina.
    for complete engine overhaul. then sa weekend, ipapa machine shop ang makina
    #35
    good to hear na walang nangyari masama kay commander sir...delikado pa naman yun tumirik sa expressway.
    anung zz yan sir? as in altis 1.6? 3zzfe? naku nakakatakot naman
    Aug 2005
    #36
    Quote Originally Posted by aejhayl17 View Post
    1.6E A/T I think this is 3zzfe. Nov 2001 nabili ng first owner. Dec 2007 nabili namin from the 2nd owner.
    buti na lang naitabi nya mula fast lane to the shoulder. North bound siya kalalagpas ng caltex.
    #37
    Ouch! ... And how old is your Corolla?
    Aug 2005
    #38
    8+ years old. odometer is at around 120,000+ km
    #39
    nine year old ZZ series engine. Did you maintain a strict service intervals at 5000 km between services?
    Aug 2005
    #40
    the first owner used full synthetic after the 10,000km pms. and from the record, nasusundan naman ang every 10K pms. got the ZZ Dec 2007. using RP during oil changes every 10,000Km
Black Sludge and Toyota/Lexus
