The online Baldwin seller now only sells filters if you get Royal Purple oil from him too. Package deal kumbaga. It kinda makes sense to me because I follow a 6-month OCI using Delo Gold Ultra on our daily driven Vios. Royal Purple should be good for 1 year.
DGU
900 oil + 300 filter + 300 labor = 1500 x 2 = 3000
Royal Purple
2200 oil + 300 filter + 300 labor = 2800
Meron pa nagbenta ng Baldwin oil na hinde package.
just checked my odometer and maintenance record, lampas na pala ako sa 5k km....
e gamit ko lang na langis e yung caltex super diesel oil api CD.....atsaka baldwin oil filter syempre....
will change the oil this weekend. most likely same brand of oil again.
so far wala naman akong naramdaman na kakaiba sa performance.
yung baldwin filter e sa next 5k km reading pa.
Ano ba talaga real life experience niyo sa Baldwin filter vs Vic vs OEM?
Paano niyo nasabi na mas maganda talaga Baldwin?
Baldwin nilagay ko last weekend sa isang kotse. Parang wala naman difference.
If I based it sa review sa net malaki daw talaga difference compare to Vic. But gusto ko malaman saan ba kayo nag based?
hmmmmmm.....sa aking pananaw lang naman.
actually hindi ko ramdam ang difference with respect sa daily performance....
ang pinagbasehan ko lang naman e yung mga teknikal na terms na ginamit sa isang thread na nandirito. beta ratio ba iyon, ek ek....
kumbaga (good) long term effect brought upon by finer filtration, yadah yadah.....hihihi
tsaka yang brands na yan ang halos gamit ng mga heavy equipment operators at kahit military (ayon sa mga forum na aking napuntahan)....baldwin, donaldson, fleetguard...
Ako dito ako nag base ng gagamiting oil filter.
Oil Filter Comparison Study - GM Truck Central
yan din ang katanungan ko sa sarili ko.
OEM toyota vs Vic vs Baldwin vs Bosch sa sasakyan namin. shell R4X ang oil.
Vic at Baldwin mas matagal mangitim ang oil versus OEM toyota at Bosch. mas mabigat din ang Vic vs Bosch kaya naisip ko na baka mas makapal filter media nito.
kaya balik Vic ako, opinyon ko lang naman, parehas lang sila ng Baldwin, readily available pa ang Vic sa mga auto supply.
mga naging taxi namin, Vic lang ever since, hanggang ngayon ok pa makina. yung isa private na, ok na ok pa din.
may offer sakin yung bagong Vic oil filter, double filter, kaso pang low viscosity oils lang, hindi ko pa nasusubukan. pang XW-30 and lower. may naka indicate mismo sa box na for low viscosity oils lang.
siguro yung mga naka bad experience sa Vic, fake yung nabili. mahal na din ang Vic filter ngayon, mas mahal pa sa Bosch na binibili ko sa Bosch center mismo (caltex paranaque).
Exactly what I was thinking. Lahat tayo either OEM then switch sa Vic after warranty wala naman naging problema sa mga engines.
Kasi iniisip ko kung for long term na mas maganda eh ganun din naman pag Vic gamit hanggang magbenta kotse wala naman problema.
Baka nadala nanaman tayo sa hyped.
Unless Meron mag test sa atin na same cars, same oil then filter lang ang iba tapos after 5k kms compare yun oil. Kahit wala ng analysis, kahit yun itsura lang ng oil.
Baka tama nga si OB. dahil kapangalan lang ng Hollywood actors. [emoji847]
Even a roll of toilet paper could be used as an oil filter. If oil is being changed every 5k, there is no or not much difference. Baldwins are desinged for extended use hence, it's better built. This just means Baldwins would stay effective longer. I think there's a discussion about this on the "By-pass Filtration" thread.
I also did not observe any difference on how the engine runs between using a Mitsu filter and a Baldwin. A bigger factor for this, I believe, is the oil being used.
Used oil analysis will definitely answer our curiosity. I'm planning to do this but my next oil change would be around next year.
I did a test for the fuel filter vic vs baldwin. Around 13K kms, the vic have shown probles with fuel delivery. Baldwin can go 20K without problem. Sa performance wala pinagbago, pero sa cost malaki. Labor pa lang twice ka sa vic, once lang sa baldwin. just my experience though.
Pero what my practice is, I always replaced filter together with the oil. Kahit fully synthetic pa Yan. I've never change oil without replacing the filter as well.
Alam ko Meron gumagawa na in the middle of certain kilometers either palit oil or filter lang siguro yun mga ganun practice pwede Baldwin.
Wala po sa timbang yung filtration quality, since pwede nilang pakapalin yung metal casing ng oil filter, tandaan niyo parati ang filter media ang pinaka important pag dating sa filtration since ang filter media ang nag fifilter ng contaminants hindi yung weight ang basehan, for example ang isang low quality oil filter mabigat nga ang overall weight niya pero yung filter media quality(depende sa materials used) wala sa industry standard eh wala din silbi.
"The typical OEM or standard replacement oil filter with cellulose fiber media will trap about 97.5 percent of most particles that are 15 to 40 microns in size or larger."
Oil Filters: Quality Matters | KnowYourParts
