Quote Originally Posted by Iskokikoy View Post
I would not recommend you doing the stop/start method specially if you are using a small or weak battery.
Battery
- will wear faster as it does not get charged properply since you keep on using its reserve charge and cranking amps
Starter
- would wear out faster since you are burning up the windings faster.
- you are also over working the bendix drive ad the starter solenoid
On board electronics
- since you mentioned that you are a grab driver means you are using a new car... with lots of electronics and sensors. Weakening the battery may cause loss of current in your electrical system causing failures.
My simple advise would be to just lower your a/c setting to a good not to hot temp to lessen fuel consumption and drive very mildly. It will also help leghthen the life of your compressor, your engine, and your wallet.
battery.... is warranted naman. motolite
starter... wear and tear.... windings won't burnt out that fast. solenoids are cheap
electronics have protection circuits... any electronics failure recently?
