Results 1 to 10 of 25
- Jun 2010
- 33
November 4th, 2012 09:13 PM #1good evening. i have a problem on my L300 van,diesel 4d56 engine.the problem is hard to accelerate, specially during overtaking. the response is delayed.what id the possible cause of it?thanks in advance
November 4th, 2012 09:50 PM #2
that's really not surprising. the L300 is remarkably slow. very slow infact.
Well if it got slower, better check your fuel. There might be contaminants in the diesel you are using like water.
- Sep 2012
- 94
November 4th, 2012 10:58 PM #3you'd have to manage your expectations, baka naman you're expecting car like acceleration from an L300, which most probably has aged already, not produced for sometime na, chassis cab na lang ang produce ng mmpc, consider also the weight, its a van and most probably pag ginamit mo may laman, and tranny, not really designed for quick acceleration and it is attached horizontally across your steering wheel, mahirap ikambyo ng mabilis
pero kung basic acceleration, baka engine tuning lang
November 5th, 2012 12:08 AM #4
TS, when did you last replace air and fuel filter? Try to replace those first if matagal na. Also, if luma na car mo, baka puro gunk na yung intake manifold mo.
November 5th, 2012 07:19 AM #5
Sir, hows you mileage? Everyday use?If m0re than 50-100t km check your fuel injection pump( palinis nyo po) and replace nozzle tip. Another thing is to check your compression ratio of you engine, timing belt, change oil etc..
- Jun 2010
- 33
November 5th, 2012 07:59 PM #6air filter napalitan nung last change oil, fuel filter ang hindi pa,try ko muna patune up, palit narin fuel filter. nasa magkano ba fuel injectors? baka mas ok kung palit nalang ng bago kesa linis injectors,
November 6th, 2012 11:55 AM #7
Hi.
Same problem here. Had to sell my l300, less than 2 years old. Maitim ang usok pag alanganin ang hataw sa gear number, nahuli ng smoke belching around 1 year of use. Hayun binenta ko na at pinalitan ng Kia KC2700. So far so good naman.
Our strada with same engine, turbo nga lang, parehas din - may sumpong ng nabibilaukan. May time na pag hinataw mo,ayaw mag respond, parang gusto pang mamatay ng engine. Brought it to Diamond- Marcos, wala daw makitang problema. Casa maintained pa yan ha.
Registered User
- Sep 2011
- 1,313
November 6th, 2012 05:58 PM #8nag kaganito rin dati yung adventure namin , try to calibrate the nozzle and clean the injection pump , yung samin kasi bumalik sa dating takbo niya .
- Jun 2010
- 33
November 6th, 2012 08:25 PM #9
Registered User
- Sep 2011
- 1,313
November 6th, 2012 10:19 PM #10
The Yokohama BluEarths notoriously break down as you use them. I guess something in their...
Finding the Best Tire for You
