Results 11 to 20 of 25
November 7th, 2012 12:42 PM #11
November 7th, 2012 01:34 PM #12
- Jun 2010
- 33
November 9th, 2012 07:36 PM #13
November 9th, 2012 07:46 PM #14
- Jun 2010
- 33
November 9th, 2012 08:58 PM #16
November 10th, 2012 06:19 PM #17
not calibrate, balance lang ang nozzle tips. usually less than 100 petot per injector ang charge. then valve clearance ipa adjust mo rin. ang power ng 4d56, nasa 13. palit ng air filter rin, baka barado na. let your engine breath. lastly, makupad ang 4d56. if you want faster acceleration, change car ka.
November 11th, 2012 11:01 AM #18
check the basics first:
1. timing check. retension timing belt if out of specs. replace t-belt if necessary also.
2. check the three filters: air, fuel and oil. replace if necessary as well as the oil
3. check valve clearance. check also rocker arms/tappets for cracks. nagpalit na rin ako neto 3 years ago. mahina manakbo dati nung di ko pa napalitan rocker arm.
3. check also for dragging brakes.
4. check your clutch for wear
5. if all else fails, then check the fuel injection pump for calibration or replacement of parts.
6. nozzle tips for cleaning or replacement. walang remedyo sa nozzle tips. replacement talaga ang bagsak mo dito kung di na maayos spray pattern. di pa ako nagpalit sa pickup ko pero sa small diesel kubota na inayos ko eh nagimprove ang hatak. sa kaibigan ko na farmer iyon gamit nya sa handtractor, tuwang tuwa nga sya nung naayos eh.
for item #5 & 6, try mo siguro yung 2T. it may do some cleaning sa nozzle tips. check mo na lang yung thread regarding this. as per experience, nabawasan ang smoky exhaust.
i dont believe na slow ang 4d56NA. ambibilis nga mga nakakasabayan ko na FBs. hehehe.Last edited by miked; November 11th, 2012 at 11:07 AM.
Registered User
- Sep 2011
- 1,313
November 11th, 2012 11:37 PM #19
Registered User
- Sep 2011
- 1,313
November 11th, 2012 11:43 PM #20
Anong Chinese brand na ba ang available sa market? Yung Leoch brand may nakita na ko post sa FB....
