Page 2 of 4 FirstFirst 1234 LastLast
Results 21 to 40 of 62
    Aug 2012
    Quote Originally Posted by sirkosero View Post
    Di rin nagwork in reviving the battery. Off to buy a new battery
    What ctek model ang ginamit mo?
    Sent from my D5833 using Tapatalk
    Sira na yata talaga yung battery. Baka too late na rescue na.
    Almost 3 yr old motolite. Sana umabot ng 5 years
    Jun 2005
    ^ CTEK MXS 5.0
    Jun 2005
    ^nakakabit yung battery mo sa car while on recond mode?
    Medyo delikado kasi 15.5 volts ang output ni ctek sa phase 3. Yung phase 1 (deslphate) nya pa is AC baka madali ECU paps.
    ^yep nakakabit. Nakalagay sa manual ok lang and no need to remove batt. Or mali nabasa ko?
    Jun 2005
    Tama ka naman though i wouldn't risk it considering na 12volt system yung car pero 15.5 volts ang output ng charger. Mahirap masira yung ECU madali lang naman tanggalin ang negative ng battery then connect the charger. He he he.
    Although mukha naman adaptive output yung ctek
    Sep 2013
    TS, per your subject heading, there's no such thing as stupid question. the more we ask, the more we learn.
    Sabagay. If ever negative lang ba tatangalin? Or both positive and negative?
    Aug 2012
    Mine also charges the battery connected to the car. The user manual says it is okay. This is an automatic 7-stage charger desulfator, with reverse pulse tech.
    Quote Originally Posted by red_one View Post
    I have tried this and confirmed that this works, without removing the battery connection and no ill effect on the ECU.
    ^ i have something similar to that although i have yet to use it. siguro mga para sigurado kelangan ko i-disconnect ang negative bago i-charge ang batt
    btw, ano ba dapat reading sa volt meter (more or less) para malaman na medyo mahina na ang battery? maganda pa naman kasi ang cranking. tnx
    Jul 2016
    Okay lang icharge kahit nakakabit pa sa makina kahit i switch ON/accesories ok lamg din especialy if good brand car charger gamit mo... Wag mo lang i-crank starter at masira charger. I do this when I program the ecu on my 2016 everest. Matagal process and para di macorrupt data transfer during programming, due to low batt, naka connect lagi battery charger ko.
    You may want to charge if reading is 12.5 and below. Do your reading first thing in the morning pag gising mo para accurate ung value at di makuha ang surface charge.
    Aug 2013
    depende din ata sa engine. yung sa corolla ko dati, kapag 12V, hirap na paikutin starter.
    sa hilux naman, 12.2V pa lang ayaw na. haha
    Jul 2006
    I find it more proper to dismount the battery and charge it on a bench, or counter top. I have an old Bosch Battmax battery charger.
    With the battery out, I have this chance of cleaning debris accumulation on and below the battery tray, and on the areas directly below the battery. Keeps everything neat and tidy.
    Jun 2005
    Yung sakin, tanggal lang negative ng kotse...
    Aug 2012
    Some cars medyo nakatago ang battery. That is you need to remove some parts pa to access battery. Example, yung sa ASX. My charger can work with battery connected to the car so no need to remove pa. This is quite common to automatic battery chargers.
    Aug 2012
    Jun 2015
    My battery can't start my car anymore. Happened just 2 hours ago. I was able to drive home with the help of my powerbank with jumpstart function.
    I'd rather not go out tonight to get a new battery. My plan is to start it up tomorrow morning again with the powerbank then drive over to a battery dealer. Right now, the car is parked at home with alarm on and doors locked. Is there any chance that the battery will totally drain overnight because of the alarm being left on? If it totally drains, will I still be able to jumpstart with a powerbank?
    By the way, nag-check engine bigla after kong i-start. Side effect ba ito ng pag-jumpstart?
    your battery can't hold its charge for long periods (longer than, say, 15 minutes) anymore, even if it is not connected to anything.
    patay na po siya.
    you can probably still start the car, with the use of your powerbank.
    Jun 2015
    patay na po siya.
    Yes, the battery was indeed dying. Since it's a weekend car, I waited 6 days to buy a replacement. By then, the battery voltage was already down to 8V. Powerbank was still able to start it up but since there was a bit of hesitation in cranking, I kept it running and drove to the nearest battery dealer pronto.
Stupid question about dead car battery (car wouldn't start)
