Page 3 of 7 FirstFirst 1234567 LastLast
Results 21 to 30 of 62
    Jun 2005
    #21
    ^ CTEK MXS 5.0
    #22
    Quote Originally Posted by sirkosero View Post
    Di rin nagwork in reviving the battery. Off to buy a new battery
    Sira na yata talaga yung battery. Baka too late na rescue na.
    Almost 3 yr old motolite. Sana umabot ng 5 years
    Jun 2005
    #23
    ^nakakabit yung battery mo sa car while on recond mode?
    Medyo delikado kasi 15.5 volts ang output ni ctek sa phase 3. Yung phase 1 (deslphate) nya pa is AC baka madali ECU paps.
    #24
    ^yep nakakabit. Nakalagay sa manual ok lang and no need to remove batt. Or mali nabasa ko?
    Aug 2012
    #25
    Mine also charges the battery connected to the car. The user manual says it is okay. This is an automatic 7-stage charger desulfator, with reverse pulse tech.
    Sent from my D5833 using Tapatalk
    Sep 2013
    #26
    Quote Originally Posted by Vodka View Post
    been living under a rock? it's called a car battery charger. you plug it into 220vac. it outputs 13 something volts DC to charge a lead-acid
    my theory is if you could somehow zap or jolt or overcharge the car battery to make it start the car one last time. it's pretty obvious you haven't tried it and you don't know jack $hit about this topic so please don't troll. thanks
    it depends on engine size, condition/age, compression ratio etc... if your powerbank can produce 200 to 500 cold crank amperes then it can start your car. there you go... I hope i answered your question
    Jun 2005
    #27
    Tama ka naman though i wouldn't risk it considering na 12volt system yung car pero 15.5 volts ang output ng charger. Mahirap masira yung ECU madali lang naman tanggalin ang negative ng battery then connect the charger. He he he.
    Although mukha naman adaptive output yung ctek
    Sep 2013
    #28
    TS, per your subject heading, there's no such thing as stupid question. the more we ask, the more we learn.
    #29
    Sabagay. If ever negative lang ba tatangalin? Or both positive and negative?
    Jun 2005
    #30
    Yung sakin, tanggal lang negative ng kotse...
Stupid question about dead car battery (car wouldn't start)
