Page 1 of 4 1234 LastLast
Results 1 to 20 of 62
    Feb 2014
    suppose your car wouldn't start due to end-of-life battery. can you somehow recharge it or something to make it start the car one last time? just to get you home...
    Not charge but you can use jumper cables and another car to start your car.
    Feb 2014
    my question is if there is something that can be done to the "dead" battery to make it start the car one last time. can you apply an overcharge for example
    Its dead because it can't hold a charge anymore.
    Feb 2014
    i'm asking because i have this large lithium-ion "powerbank" that outputs 220vac, enough to power a car battery charger. would be a potential lifesaver if this could work...
    You could probably use that to jumpstart the car. You are not charging the battery, but instead coursing the current through the dead battery and into the starter. Once you got the car running, you don't even need the battery.
    Feb 2014
    youre kidding right, you can't jump start a car w/ 220vac
    Well you're the one wondering if it can be used in the first place. Already told you a dead battery will not charge. If you figured out the 220VAC battery can't start a car, what makes you think it will charge a battery?
    Feb 2014
    been living under a rock? it's called a car battery charger. you plug it into 220vac. it outputs 13 something volts DC to charge a lead-acid
    my theory is if you could somehow zap or jolt or overcharge the car battery to make it start the car one last time. it's pretty obvious you haven't tried it and you don't know jack $hit about this topic so please don't troll. thanks
    Nov 2012
    Get a battery charger with desulfator function .... might bring back the dead battery back to life
    Sent from my LG-H950 using Tapatalk
    Aug 2015
    Quote Originally Posted by Vodka View Post
    Not sure bout the specifics. But i had friend help me out using a powerbank when my almost 5 yr old motolite decided to quit on me in a mall parking.
    Jun 2012
    Pwede i-charge. Pero ang alam ko matagal ang charge nun ah. Hrs ang bilang. Tapos pag nagstart na, 1 day lang yun, pag start mo the next day dead ulit yun
    Sent from my SM-A9000 using Tapatalk
    Quote Originally Posted by dct View Post
    Kung ganun din naman, eh tumawag ka na lang sa Motolite o kung anong battery shop at magpa-deliver ng bago.
    1. some batteries can hold enough juice for a few minutes, so that you can start a car very shortly after the battery was charged by a battery charger. but if you wait a few more minutes, you won't be able to do it.
    2. some MT cars can (easily be) push-started, even with a dying battery. it takes a lot less electricity to power the sparking circuits, compared to the starter's requirements. but i am told, some of today's newer cars may not be push-started, due to built-in safety features; i don't know about those.
    3. a very dead battery may not even light a flashlight bulb.
    if you have an AT or CVT car, it is a good idea to have a battery charger at home, or motolite's battery delivery number.
    do those mall-advertised handhelds work? i do not know.
    if a 15 to 30 minute charge doesn't do it, 2 hours' worth probably won't, either.
    we are charging the battery so's it can power the starter; we are not charging it to full rated capacity. hence just a few minutes' charge.
    Feb 2009
    sometimes, sulfated batteries can be revived if you use a seven stage battery reconditioner. i have used them on AGM, maintenance free, gel cell and flooded batteries with success when the regular battery charger has failed.
    VMAX 12V 15A 7-Stage AUTOMOTIVE BATTERY "Smart" Charger Maintainer Tender | eBay
    Jun 2005
    TS balitaan kita in a few days.
    Mau battery ako dito na sira. 6v na lang ang naiiwan na charge even after charging it for 2 days straight.
    I borrowed a battery charger with desulfator, yung ctek. Currently in the process of 'reviving' the battery
    Jun 2005
    Di rin nagwork in reviving the battery. Off to buy a new battery
    Sep 2009
    Even if these work, it's too risky to leave a highly combustible object in your car. The reason I just change battery regularly.
    Aug 2012
    Quote Originally Posted by sirkosero View Post
    What ctek model ang ginamit mo?
    Sent from my D5833 using Tapatalk
Stupid question about dead car battery (car wouldn't start)
