Results 1 to 10 of 62
- Feb 2014
- 2,536
December 3rd, 2016 10:48 PM #1suppose your car wouldn't start due to end-of-life battery. can you somehow recharge it or something to make it start the car one last time? just to get you home...
- Oct 2006
- 5,697
December 3rd, 2016 10:52 PM #2Not charge but you can use jumper cables and another car to start your car.
- Feb 2014
- 2,536
December 3rd, 2016 11:04 PM #3my question is if there is something that can be done to the "dead" battery to make it start the car one last time. can you apply an overcharge for example
- Oct 2006
- 5,697
- Feb 2014
- 2,536
December 3rd, 2016 11:07 PM #5i'm asking because i have this large lithium-ion "powerbank" that outputs 220vac, enough to power a car battery charger. would be a potential lifesaver if this could work...
- Oct 2006
- 5,697
December 3rd, 2016 11:19 PM #6You could probably use that to jumpstart the car. You are not charging the battery, but instead coursing the current through the dead battery and into the starter. Once you got the car running, you don't even need the battery.
- Feb 2014
- 2,536
- Oct 2006
- 5,697
December 4th, 2016 02:03 PM #8Well you're the one wondering if it can be used in the first place. Already told you a dead battery will not charge. If you figured out the 220VAC battery can't start a car, what makes you think it will charge a battery?
- Feb 2014
- 2,536
December 4th, 2016 02:32 PM #9been living under a rock? it's called a car battery charger. you plug it into 220vac. it outputs 13 something volts DC to charge a lead-acid
my theory is if you could somehow zap or jolt or overcharge the car battery to make it start the car one last time. it's pretty obvious you haven't tried it and you don't know jack $hit about this topic so please don't troll. thanks
- Nov 2012
- 95
December 4th, 2016 03:34 PM #10Get a battery charger with desulfator function .... might bring back the dead battery back to life
Sent from my LG-H950 using Tapatalk
MotorImage?
Car Sales Data (2024)
