Results 1 to 10 of 30
- Apr 2009
- 100
May 29th, 2014 02:09 AM #1Ano po kayo problema? Pag po ginamit ung sasakyan tpos pag off po after ilan minutes try mo magstart ayaw magredondo ng starter click lang po ang naririnig ko galing po un sa relay hindi po sa starter. Napalinis ko na po starter at ilan days lang bumalik nanaman problema.
- Jul 2010
- 570
May 29th, 2014 09:30 AM #2Malakas sa kain ng current ang starter. Kaya kapag may loose connection ay hirap umandar uli. Check mo body ground connection ng starter. Yun malaking wire. Saka yun malaking wire nakakabit sa mga Battery Terminals na para din sa Starter. Try mo higpitan uli. Minsan lumuluwag iyan kahit di mo ginalaw.
- Apr 2009
- 100
May 29th, 2014 07:51 PM #3
- Mar 2014
- 55
May 29th, 2014 10:47 PM #4baka mahina na ang battery Sir, check mo na rin yong ignition wirings, maganda pa alisin mo yung positive kung hindi mo gagamitin yong sasakyan, ganyan ang ginagawa ko tumatagal pa ang battery ko.
- Jul 2010
- 570
May 30th, 2014 10:45 AM #5
May 30th, 2014 12:01 PM #6
you may try to check the relay also, pwede kasing ubos na contact point sa loob nito kaya puro click na lang nadidinig mo at wala ng current na tumatakbo papunta sa starter. kung kaya mo irekta yung (+) wire ng starter sa battery matest mo ito kung saan and problema
June 3rd, 2014 11:15 AM #7
Ganyan din problem nung dati ko na kotse. Better check on the OEM body grounds baka yun ang culprit. Napansin ko din dati mainit yung negative cable ng battery.
- Nov 2006
- 1
- Mar 2014
- 901
August 4th, 2014 10:07 AM #9Im having same problem too. Even with a new installed battery, minsan click lang madinig. Pero after ilan several attempts to start, mag-redondo naman to start. Palitin na po ba ang starter?
August 4th, 2014 10:39 AM #10
have you tried spraying peppermint?
How to get rid of kittens in the engine bay
