Results 1 to 20 of 30
    Apr 2009
    Quote Originally Posted by Chinoi View Post
    Malakas sa kain ng current ang starter. Kaya kapag may loose connection ay hirap umandar uli. Check mo body ground connection ng starter. Yun malaking wire. Saka yun malaking wire nakakabit sa mga Battery Terminals na para din sa Starter. Try mo higpitan uli. Minsan lumuluwag iyan kahit di mo ginalaw.
    sir ginawa ko narin po yan nagdagdag na rin po ako body ground pero ganun pa din po.
    baka mahina na ang battery Sir, check mo na rin yong ignition wirings, maganda pa alisin mo yung positive kung hindi mo gagamitin yong sasakyan, ganyan ang ginagawa ko tumatagal pa ang battery ko.
    Jul 2010
    Quote Originally Posted by darkheim6900 View Post
    Assuming malakas pa battery mo ay posible hindi maganda pagkalinis ng Starter mo. Dapat nililiha yun Commutator at palit Carbon Brush kung pudpod na ito.
    Attached Thumbnails Attached Thumbnails cleanedcommutator_zpsc4f03915.jpg   dirtycommutator_zps9c627272.jpg
    Dec 2012
    you may try to check the relay also, pwede kasing ubos na contact point sa loob nito kaya puro click na lang nadidinig mo at wala ng current na tumatakbo papunta sa starter. kung kaya mo irekta yung (+) wire ng starter sa battery matest mo ito kung saan and problema
    Jan 2003
    Ganyan din problem nung dati ko na kotse. Better check on the OEM body grounds baka yun ang culprit. Napansin ko din dati mainit yung negative cable ng battery.
    Nov 2006
    May single line diagram po kau? pde maki.hingi.. salamat po...
    Im having same problem too. Even with a new installed battery, minsan click lang madinig. Pero after ilan several attempts to start, mag-redondo naman to start. Palitin na po ba ang starter?
    Jun 2008
    Quote Originally Posted by rodetor View Post
    Better have it checked where you bought the battery, just to be sure. Ano ride po boss? i also had the same problem but after checking the battery, lakas ng re-dondo, i found out the fuel pump's socket was loose & no gas was pumping... hehe...
problem starting after turning off
