Results 1 to 20 of 30
    Dec 2012
    you may try to check the relay also, pwede kasing ubos na contact point sa loob nito kaya puro click na lang nadidinig mo at wala ng current na tumatakbo papunta sa starter. kung kaya mo irekta yung (+) wire ng starter sa battery matest mo ito kung saan and problema
    Jan 2003
    Ganyan din problem nung dati ko na kotse. Better check on the OEM body grounds baka yun ang culprit. Napansin ko din dati mainit yung negative cable ng battery.
    Nov 2006
    May single line diagram po kau? pde maki.hingi.. salamat po...
    Im having same problem too. Even with a new installed battery, minsan click lang madinig. Pero after ilan several attempts to start, mag-redondo naman to start. Palitin na po ba ang starter?
    Jun 2008
    Quote Originally Posted by rodetor View Post
    Better have it checked where you bought the battery, just to be sure. Ano ride po boss? i also had the same problem but after checking the battery, lakas ng re-dondo, i found out the fuel pump's socket was loose & no gas was pumping... hehe...
    Quote Originally Posted by mbk347 View Post
    Honda City 1st Gen ride ko po. Same issue with the old battery. Nai-start naman po. Ang concern ko lang, may pagkakataon minsan na ayaw magredondo at click lang marinig sa pagpihit ng susi sa start. Kaya minsan sa pagpihit ng susi sa start, kapag hindi umandar sa 1st try, makaka-ilan attempt pa ako sa pag-start minsan. Palitin na po kaya ang stater?
    ano po yan automatic?
    Honda City 1st Gen ride ko po. My concern is the starting issue even with a new battery. same issue encountered with the old battery which made me decide of changing the battery. Same type and brand. Ang sitwasyon ay ganito, minsan pag-start hindi mag-redondo at click lang marinig,pero trying to attempt several times, kapag rumedondo i-start naman. Minsan 1 attempt lang to start, minsan several attempts pa para sya umandar. Kaya ko sir na ask kung palitin na ang starter ko.
    Honda City 1st Gen ride ko po. My concern is the starting issue even with a new battery. same issue encountered with the old battery which made me decide of changing the battery. Same type and brand. Ang sitwasyon ay ganito, minsan pag-start hindi mag-redondo at click lang marinig,pero trying to attempt several times, kapag rumedondo i-start naman. Minsan 1 attempt lang to start, minsan several attempts pa para sya umandar. Karya ko sir na ask kung palitin na ang starter ko.
    If you can do it, bago mo icondemn yung starter, make sure na nakakarating yung 12V sa starter solenoid/relay para paikutin yung starter. Or else any competent electrician will be able to tell you the problem
    starters are very robust components. they can outlast the engine.
    as the others have pointed out, maybe your problem is just the starter solenoid. or the ignition key contacts.
    a good auto electrician can find out.
    Aug 2014
    same sa bighorn ko mga ka tsikot..minsan aandarin ko madali siya mg start.. after a minute off mu siya...start mu ulit ayw na mg start..stand by lng ng kahit 20 minutes gagana na namn siya...3 dyas pa lng battery ko...palit na rin ako ngalternator ok namn starter ko.. ano kya probs nito mga sir..TIA...
    Jan 2011
    armateur mo sir, baka grounded.. pag mainit ang makina, mahirap mag start. pero kung malamig ang makina, 1 click lang yan.
    Apr 2009
    Quote Originally Posted by shelu View Post
    Ganyan na ganyan po symptom ng sasakyan namin. . Ano po ginawa sa armateur nyo? Hangga ngaun pinagtyatyagaan pa din namin ung problema pati electrician suko na sa kakalinis. . Balak ko na nga bumili ng starter pero gusto ko ma sure kung starter nga ang problema. .
problem starting after turning off
