Results 51 to 60 of 125
March 27th, 2017 10:01 AM #51
- 54,293
March 27th, 2017 10:22 AM #53
plano ko sa MF ko bro, buksan tapos top up hehehe
15 months warranty kasi yung 3k battery nabili ko last year, tapos yung pinalitan nya (motolite); pwede pa daw sana kung natubigan agad, kaso MF nga. nilagyan ng tubig nun taga motolite, sinabi sakin bawal daw yun pero mukha daw ako poor kaya ginawa nya. abot pa daw yun ng 1 year, pero di na marerestore.
bro di ba low MF yun stock?
March 27th, 2017 10:28 AM #54
March 27th, 2017 12:24 PM #55
^Mas bugbog ang battery sa gas kasi spark ignition requires battery charge. When your alternator fails the spark plugs can only depend on the RC (reserved current) of the battery to keep running. RC is measured in minutes, that means after the alternator failed to supply the battery the battery have only that much time to keep on supplying electric charge to the spark plug. After which the engine will seize to operate, so its important to note the RC specification of the battery installed in your car. Turning off the entertainment system will help in this scenario
Diesel utilizes compression ignition that does not require battery charge. You can keep a diesel engine running without a battery, only after push starting it ofcourse for manual or jump starting it with another car for automatic. In the event the alternator fails, the engine will just keep on running. The only thing the RC could be useful for is your entertainment
We can only prolong the life of a battery by keeping the cells wet, we cant restore it back to its original glory as acids deteriorate the metalic component of every battery
Sent from my GT-P3110 using Tsikot Forums mobile appLast edited by kisshmet; March 27th, 2017 at 01:09 PM.
March 27th, 2017 12:38 PM #56
Dapat sulphuric acid nilagay mo, that fluid contains more ions that facilitate flow of electricity
Distilled water is for topping up only because its presumed that the cell still contain lead acid
A dry cell is an open circuit, it wont facilitate flow of electricity, adding distilled water contains minimal ions that facilitaded electric flow so it has no adverse effect. You could have energized the battery more had you utilized sulphuric acid fluid instead
Sent from my GT-P3110 using Tsikot Forums mobile appLast edited by kisshmet; March 27th, 2017 at 12:42 PM.
March 27th, 2017 10:03 PM #57
meron akong innova gas na 2005 model...
1st battery (stock GS high maintenance) - had it replaced after 6 years.
2nd battery (motolite gold MF) - more than 5 years in counting. kaya depende siguro sa electrical system ng isang sasakyan yung life span ng battery. my diesel fed TBZ's stock ac delco battery only lasted for 2 years.
Sent from my SM-N9005 using TapatalkLast edited by Gumusut_Amige; March 27th, 2017 at 10:06 PM.
March 27th, 2017 10:38 PM #58
^sana yun exact type, model, manufacturing date at size ng delco battery ng diesel car mo ang ginamit mo sa gas car mo to fairly compare
Sent from my GT-P3110 using Tsikot Forums mobile appLast edited by kisshmet; March 27th, 2017 at 10:42 PM.
May 1st, 2017 08:06 AM #59
sino may alam paano baklasin yung top part ng 3k battery?
sa motolite kasi kahit papaano pwede mo tanggalin lang sticker, kita na yun paglalagyan ng tubig. sa 3k kasi flat lang, sa ilalim bakat yung mga holes. thanks!
- Apr 2010
- 742
May 1st, 2017 08:56 AM #60
Yung extra AUX Fan is useful sa mga naka montero. Mag improve daw yung AC system since may extra...
