Page 1 of 3 123 LastLast
Results 1 to 20 of 125
    Jun 2008
    ano ba mas ok yun low or no maintenance battery?
    no brainer... maintenance free batt...
    Aug 2005
    Ok lang sa akin ang mantenance needed na batteries. kasi at least once or twice a month, I check my fluids. kasama na dito ang battery. I do this when I wash the car.
    maintenance needed kasi ang stock na battery ng Avanza. GS ang brand
    how about the performance, parehas lang ba? as long as maintained?
    Aug 2005
    For me, for local use, this GS brand is not a good brand, dahil mga mga nagpalit na from the stock GS to Motolite.
    Assuming na maintenance needed na motolite at maintenance free na motolite. Same lang naman ang performance. Baka nga after a year or 2 baka ang well maintained na maintenance needed na battery will perform better.
    Jun 2007
    Maintenance free for me
    IMHO, Maintenance-free kasi I can forget it for a year or two... but just make sure you get a good quality battery - yung GS parang dami ng news na palpak - pinapareacall na yata ng DTI yan.
    Aug 2006
    Quote Originally Posted by SusieQ View Post
    GS, I had a long long time bad experience with it, died just 4 months of use and never got a replacement. Sa galit ko pull-out ko na lang and then drop it on the floor and walk away.
    Jan 2008
    I guess what it boils down to is what type of car owner you are. Kung masipag kang magkaka-kalikot under the hood, then go for a Low Manitenance battery. On the other hand, if you regularly "forget" (or don't normally bother to) look under the hood, then go for the Maintenace-free kind.
    In my experience, I have had a lot of car batteries die on me because I often neglect to check their water levels. So, I now get Maintenance-free batteries. Even if technically, MF batteries supposedly wear out and die faster than LM batteries, if you don't regularly check the water levels then your LM battery will have a much shorter lifespan!
    Nov 2003
    I've only tried "maintenance free" batteries. Probably bought around 7 already (several cars), all Motolite coz of the free delivery.
    In my experience, namamatay na sya soon after warranty expires (2-6 months). Mostly automatic din mga kotse namin, and hassle lang kasi kung mamatay biglaan. Example one day ok sya, next day ayaw na mag start (hindi man lang hard start the day before para may warning).
    I will try "Low Maintenance" for my next purchase. I want to compare kung mas tatagal ang properly maintained "low maintenance" vs "maintenance free".
    Balik ako maintenance free after using the stock low maintenance batt and its lmb replacement for about 3.5 years. Hassle iyong mga acidic discharge nya.
    Checking on its health is no problem for me since i try to clean the engine bay on a weekly basis anyway but its acid emissions is a chore to remove w/c gets old real fast
    to be or not to be, that always confuses me!
    Dec 2009
    ^sana yun exact type, model, manufacturing date at size ng delco battery ng diesel car mo ang ginamit mo sa gas car mo to fairly compare
    Sent from my GT-P3110 using Tsikot Forums mobile app
    sino may alam paano baklasin yung top part ng 3k battery?
    sa motolite kasi kahit papaano pwede mo tanggalin lang sticker, kita na yun paglalagyan ng tubig. sa 3k kasi flat lang, sa ilalim bakat yung mga holes. thanks!
    Apr 2010
    pictures of your battery with the top sticker removed will help
    Quote Originally Posted by ParticleX View Post
    imagine mo nalang bro, pag tanggal mo ng sticker flat parin like the sides.
    Apr 2010
    i think you need to pry the plastic:
    see this video:
    if lagpas na sa warranty do it then have it charged externally
    Thanks bro! 15 mos warranty pala sya. Ill pry it open after. By june 2017 update ko ito thread
    Sent from my D5303 using Tapatalk
    update ko lang
    bumili ako amaron last week.
    8 volts nalang output nya pag crank
    update ko lang
    factory defect?
    factory defect?
    Nope it was 3 weeks after the warranty o_O
    Sent from my SM-C900F using Tapatalk
No maintenance or Low maintenance Battery?
