Results 1 to 10 of 125
- Jun 2008
- 44
July 20th, 2008 09:52 PM #3
Ok lang sa akin ang mantenance needed na batteries. kasi at least once or twice a month, I check my fluids. kasama na dito ang battery. I do this when I wash the car.
maintenance needed kasi ang stock na battery ng Avanza. GS ang brand
July 20th, 2008 11:14 PM #5
For me, for local use, this GS brand is not a good brand, dahil mga mga nagpalit na from the stock GS to Motolite.
Assuming na maintenance needed na motolite at maintenance free na motolite. Same lang naman ang performance. Baka nga after a year or 2 baka ang well maintained na maintenance needed na battery will perform better.
July 21st, 2008 08:48 PM #7
July 2nd, 2009 10:26 AM #8
July 2nd, 2010 11:43 PM #9
I guess what it boils down to is what type of car owner you are. Kung masipag kang magkaka-kalikot under the hood, then go for a Low Manitenance battery. On the other hand, if you regularly "forget" (or don't normally bother to) look under the hood, then go for the Maintenace-free kind.
In my experience, I have had a lot of car batteries die on me because I often neglect to check their water levels. So, I now get Maintenance-free batteries. Even if technically, MF batteries supposedly wear out and die faster than LM batteries, if you don't regularly check the water levels then your LM battery will have a much shorter lifespan!
August 24th, 2011 09:30 AM #10
I've only tried "maintenance free" batteries. Probably bought around 7 already (several cars), all Motolite coz of the free delivery.
In my experience, namamatay na sya soon after warranty expires (2-6 months). Mostly automatic din mga kotse namin, and hassle lang kasi kung mamatay biglaan. Example one day ok sya, next day ayaw na mag start (hindi man lang hard start the day before para may warning).
I will try "Low Maintenance" for my next purchase. I want to compare kung mas tatagal ang properly maintained "low maintenance" vs "maintenance free".
Specs, prices, features: Everything you need to know about the all-new Hyundai Kona | TopGear PH...
Hyundai Kona (2nd Gen)
