Results 21 to 30 of 125
- Jan 2008
- 380
July 21st, 2008 12:08 PM #21Only your vehicle can tell kung ano hiyang sa kanya. In petrol cars, batteries last longer and I can appreciate no difference in longevity between low-maintenance (LMB) and maintenance free (MF) batteries.
Being in the 'tipid mode' at the moment, I currently use LMB which is about 1/3 of the the price of a good MF battery. MF are known to drop dead suddenly, something that I haven't experience yet with LMB, but had them twice with MF.
In the tropical countries , Low-Maitenance batteries are being recommended. I don't know how long the MF Motolite Enduro will last in my
diesel but I will replace it with a LMB once expired.
See:
https://www.pacificpowerbatteries.co...AQ/carfaq.html
http://batteryfaq.org/
July 21st, 2008 08:48 PM #22
July 21st, 2008 09:52 PM #23
I've had two Maintenance Free batteries die on me cold; the stock battery that came with my ride and the one I bought after it. The former gave out well past the warranty (good), the latter just four months shy of the warranty expiry (crap).
That's why I'm now seriously considering a Low Maintenance battery as my next purchase. Samahan ko na rin kaya ng voltmeter.
July 21st, 2008 10:34 PM #24
LMB is best for me, but my pops went for MF. kabili lang nya kanina. oh well, it's his ride...
Tama yan Bogeyman. maganda may voltmeter. it's where I realized what's causing our old battery dying early. dahil pala sa dalawang strong condenser fan ng aircon. improvised kasi for better cooling. but the alternator could not cope with it.
- Jun 2008
- 44
July 30th, 2008 08:03 PM #25actually sa mga motorcycles mas advisable yun LM sa MF, mas tumatagal ang battery and mas ok matagtag. i don't know sa cars yet... but based on replies mas ok talaga yun LM. siguro pagtamad ka or hectic masyado sked mo ok yun MF, imho.
July 2nd, 2009 08:11 AM #26
Keep in mind that number001 said "SEEM" and that he's only speaking from experience.
In my experience, MF batteries lasted longer than non-MF batteries.
Bottom line is, YMMV.
BTW, I have a tip for those who use non-MF batteries. A spill-free way to refill the batteries with distilled water is to use plastic catsup or mustard dispensers (like the ones they use at Shawarma outlets. Press it while its snout is inside the circular refilling hole, and immediately after releasing, you have about 1 or 2 seconds before a drop spills out.
HTH.
July 2nd, 2009 10:13 AM #27
my experience is non-MF batteries last longer. siguro dahil alaga lang talaga.
the longest non MF battery that i had used is around 4 years. for MFs, the longest is 3 years.
July 2nd, 2009 10:26 AM #28
July 4th, 2009 11:00 PM #29
July 2nd, 2010 11:43 PM #30
I guess what it boils down to is what type of car owner you are. Kung masipag kang magkaka-kalikot under the hood, then go for a Low Manitenance battery. On the other hand, if you regularly "forget" (or don't normally bother to) look under the hood, then go for the Maintenace-free kind.
In my experience, I have had a lot of car batteries die on me because I often neglect to check their water levels. So, I now get Maintenance-free batteries. Even if technically, MF batteries supposedly wear out and die faster than LM batteries, if you don't regularly check the water levels then your LM battery will have a much shorter lifespan!
190,429 cars were sold in PH, as of May 2025 | TopGear PH...
Car Sales Data (2025)
