you sounded serious hehe
Tama ginawa ko. I followed the video step by step e.
Sent from my GT-N7100 using Tapatalk 4 Beta
ya you followed step by step procedure nga but you didnt achieve the objective which is starting the car
i'm usually not in a hurry to start the car.
when i bought an AT car, i also bought a battery charger. yes, i also have a set of jumpers. but i still prefer the charger. less hassle than the jumpers..
ya that's what i do at home when the car wont start in the morning coz of weak battery
i charge the battery nalang without removing the battery from the car
15 minutes lang naman
di bale ma-late konte hehe
cdr king meron. 1200 or 1400 ata kuha ko. yung kulay green na may clamp. may flashlight pa![]()
just last night, i jump-started my diesel innova. i used the cheapest cables i could find in xxxxmart. 400 amp daw sa cover (pmpo, most probably, because the cables obviously were not thick enough. heh heh). my power source was my other diesel innova on idling. i succeeded. the cables didn't even get warm. but then, it was a single click operation..
maybe if the first car refuses to cooperate and we have to try several times, something would have warmed up considerably.
so, i suppose if it's just a simple matter of jump-starting an otherwise perfectly good car, then the cheap mall-sourced cables are fine..
and unless it's a sherman tank, it can probably be push-started even easier..
(btw, sherman tanks used gasoline engines! when a shell hit, the gas burned, killing everyone inside..)
not sure on durability pero mga 2 months ko na gamit pang testing ng sounds and electrical. ok pa naman. A full charge last around 2 days with moderate to heavy use. worth it na kung tumagal ng 1 year.![]()
