Page 7 of 38 FirstFirst ... 3456789101117 ... LastLast
Results 121 to 140 of 754
    pinag uusapan pa nila kung alin ang mauna.... kung live car o dead car... kung positive o negative
    tapos may concern ngayon baka sumabog ang maliit na 1sm battery dahil sa hydrogen
    kaya wala pa nangyayari
    Mar 2013
    #122
    Naloko na, ginawa ng science ang napaka simpleng red at black wires.
    Sasabog ang 1sm battery dahil sa hydrogen? Seriously?!?
    in theory yes coz a charging battery would produce hydrogen fumes that could ignite
    pero kung dead battery yan and you jumper-cable it to a live 1sm battery of a another car... in those few minutes of being connected gaano kadami hydrogen fumes and ma--produce niyan?
    buti sana kung kinabit mo sa battery charger and let it charge for many hours... kung ganyan maamoy mo talaga yung kumukulo na battery acid
    pero jumper lang yan... tapos takot ka baka sumabog ang battery dahil sa hydrogen? grabe OA na yan
    basta huwag lang mabaligtad o magdikit ang pag jumper mo di ka ma-o-ospital
    and most 1sm car batteries are like this:
    so how much hydrogen can vent out from a battery like that habang naka jumper?
    Mar 2013
    #125
    In theory indeed, but like what you said this is just a 1sm battery and you're just going to jump it. Unless they don't understand the concept of jumping a car, which is highly unlikely.
    Oct 2011
    #126
    baka ma nosebleed na si cat pag nabasa itong thread on how to jump start a dead car battery bumili pa man din siya ng jumper cable.
    #127
    Na try ko na i jumper cable. I did everything step by step pero ayaw pa rin mag start ng Corolla. I tried to start it three times pero ayaw tumuloy e.
    benta mo na yan
    #129
    Battery lang kaya problem? Ngayon lang ako naka experience ng ginamitan ng jumper cable tapos hindi tumuloy pag start Baka kasi bumili ako ng battery na bago masira lang eh it is too late for me to go to the talyer, baka mabitin pag matagal na gawaaan.
    if it cranks but wont start up it's either a fuel problem or an ignition problem
    #131
    At least isolated mo na battey, move to the next - fuel and ignition. Baka napanis fuel, may water contamination or ignition coils fouled spark plugs.
    Better have it home serviced, may pang jumper ka na for cranking.
    Kung napaandar na, have the charging system checked. Baka nasira na din ang battery due to discharge, hav it checked by bat shop,
    cathy either pa-service mo yan dyan sa house mo o pahila mo papunta shop
    #133
    Aandar ba eto pag push start? Wala naman home service kilala
    Sabi friend ko dikit ko daw daliri ko sa positive and negative. hay naku.
    sabihin mo sa friend mo siya mag tulak
    #135
    ha ha ha
    I kind of enjoy yung push start, basta hindi ako yung taga tulak
    Okay ba outlast na battery? I plan to sell the car na naman soon, medyo mahal yung motolite e.
    mahal din outlast
    meron mga mas mura di kilalang brand 6 months lang warranty
    #137
    so it can't be just a battery problem? Hay Then I need to have the AC fixed pa. When the car is idling there's no cold air/fan lang sometime mainit pa. But when the car is moving may cold air naman.
    yes. not just battery
    your battery is too weak to start the engine. either na-diskarga lang yan sa tagal so pwede pa mabuhay uli yan pag ni-recharge or sira na talaga so kailangan na palitan. that's one thing. the other thing is -- nag jumper ka na -- the engine cranks but won't start. so it's either a fuel problem or an ignition problem
    #139
    ^Hindi na talaga aandar sa tulak? Ang mahal magpa tow Sana pwede home service ang Tower of David
    #140
    ^ Reys electrical has home service. I don't know the areas they cover though since i avail of the one from their Marikina branch (QC area service).
How to Know If It Is Only A Battery Problem
