Page 5 of 38 FirstFirst 12345678915 ... LastLast
Results 81 to 100 of 754
    #81
    *12vdc, thanks. I'll look up that jumper cable pero parang gusto ko yung ni recommend ni CVT na may instruction pa. Tingin ko kaya nagkaloko loko yung Lancer ko kasi palpak mga ginagawa ko. I can't afford to do that with my Corolla anymore.
    Things I need to buy:
    Jumper Cable - minimum 200A
    Battery Monitor - Digital
    BTW wala rin pala akong EWD sa car
    CVT wag mo naman awayin si Retz
    #82
    Sorry,- can't help it Sis, especially when a fellow tsikoteer is being misled....
    BTW, the instruction is for the sequence of connect and disconnect,- for safety reasons (fumes from battery)...
    Retz- alam mo parallel ha? E iyong Wye ? Asus!...
    19.4K:tomato:
    OMG (parang Cathy no?)
    you need instructions to use a jumper cable?
    red clamp to positive terminal
    black clamp to negative terminal
    on both ends
    ibang klase talaga si cathy
    she can make a thread about battery and alternator entertaining
    #85
    Sabi ko na nga ba e....
    Mag back read ka nga...
    Multimeter ang pinabibili mo kay CFY... Pang engineer/technician ito... Hindi niya alam gumamit niyan. (Alam mo ba?)
    Puro kasi one-liner ka...
    19.4K:tomato:
    Ansakit makasalita
    Parallax nalala kopa yan yung optical error dun sa analog meter..so yeah, mas accurate digital given na well-calibrated.. Kaya hindi recommended sa test equipments yung cheap brands. Pero prefer nung iba ang analog since mas Ok filtering nya sa high frequency AC (based from my experience).
    Cath, kung cheap lang yung plugin-type na Voltmeter, go for it. Pang monitor mo atleast dapat 13.5-14.2V charging voltage/engine running.
    Kung gusto mo long term, invest ka sa proper Multitester like Sanwa, Fluke VOM - Pag ginawa mo to baka makumbinsi na si uls na cowboy ka..:rofl01:
    Eto pa additional suggestion for monitoring your car (pwede na sa altis-check compatibility chart)
    haha
    maconvince ako pag nag jeep si cathy papunta raon para bumili ng sanwa hehe
    #87
    on both ends
    Dami kaya instructions Saan ko una ikakabit yung clamp sa dead o sa working battery? Yung red ba mauna o yung black. Kailangan ba pareho nakapatay pag kinabit ko. Baka mamaya magkamali ako masira ko pa yung car. Tingin ko nga kaya nasira lancer ko dahil sa mali pag kabit ko dati hehe
    #88
    Ansakit makasalita
    Ano yan multitester, yan ata yung sinasabi ni CVT na pang engineer
    Nakapag jeep na kaya ako!
    pwede mauna either one
    pwede mauna sa altis red positive to positive ng corolla
    then yung black
    basta wag lang positive napunta negative
    #90
    then yung black
    working red positive to dead red positive
    working black positive to deal black positive
    May naalala kasi ako na may proper seqeunce e nalimutan ko na. Pati sa pag tanggal ng clamp may proper sequence daw
    Tapos una ko sisindihan yung working car diba?
    kaya i suggested tanggalin mo battery ng altis at ilagay sa corolla
    mas madali kasi para sayo yan
    mukhang mas mahirap pa sayo mag jumper cable eh
    Jul 2006
    #92
    Parasitic Load ang tamang term.
    Safe yan sa old school, mechanical-type controls. Malaki tolerance sa voltage spikes/changes.
    Yun mga de ECU at efi, pwede mo isugal pero you have been warned ika nga sa manual.. Pede masunog electronics kung hindi maganda regulation.
    Yung battery acts as filter/ regulator, parang malaking capacitor.
    O, wag kayo mag away. Baka lalo maguluhan si TS
    Exactly what I was saying, and the two other gentlemen before me. Glenn and Jeff.
    Mar 2013
    #93
    Dapat tinangal na yung battery ng altis at nilipat sa corolla per uls advice para madala na yan sa pagawaan.
    Loko tong mga tsikot boys kung ano-ano ang mga pinapa bile. Nakiki pag talo pa regarding sa mga procedure na gagawin. Walang alam si Cathy dyan.
    #94
    Mas madali jumper cable, ayoko galawin battery ng Altis kasi mawawala setting ko sa clock, radio etc
    #95
    I like LSB's conservative approach...
    #96
    Quote Originally Posted by ClaNker View Post
    Okay lang matagal ko na talaga balak bumili ng Jumper cable. Yung battery monitor okay lang kasi kinakabahan na rin ako sa battery ng Altis ko kasi 3 yrs old na gumagana pa.
    #97
    For amateurs
    For Engineers
    For Car Enthusiasts
    ScanGaugeII | ScanGauge.com.au
    Mar 2013
    #98
    That is kung di nga alternator ang sira ng kotse mo.
    #99
    I like the first one, that's the P995 ba?
    #100
    Hindi naman talaga sira Alternator ng Altis ko e. Pag tinanggal ko batt ng Altis ko para ilagay sa Corolla eh di mawawala setting ng sa Altis ko...
How to Know If It Is Only A Battery Problem
