Page 1 of 3 123 LastLast
Results 1 to 10 of 22
    Apr 2014
    Good morning!
    Patulong sana sa problem ng Kia Carnival 08. Car wont start. OBDII reading is P0685.
    ECU/PCM power relay curcuit open. 1 1/2 months ba nka garahe ung van.
    Thanks!
    Quote Originally Posted by Paul77 View Post
    Good morning!
    Thanks!
    Potential causes for this code to set are:
    A defective PCM power relay
    A blown fuse or fusible link Corroded or damaged wiring or wiring connectors (especially near the PCM relay)
    Faulty ignition switch
    Partially or totally disconnected electrical terminal at the ignition switch
    Loose or corroded battery cable ends
    Read more at: P685 ECM/PCM Power Relay Control Circuit Open
    Copyright OBD-Codes.com
    How's the batt?
    Check the Main relay
    when you look into the abyss, the abyss looks into you
    Apr 2014
    Read more at: P�685 ECM/PCM Power Relay Control Circuit Open
    Main relay and fuse are ok.
    Battery is 1month old. Cleaned the terminals already.
    Ung engine nag ccrank pero d lng mag start. Parang mag sstart na ung crank nya
    How's the batt?
    Batt sir is new. Last oct lng nag palit.
    Apr 2014
    Main relay is ok. Abyss?
    Check fuel pressure....if low or none, proceed to filter, then pump.
    Apr 2014
    Fuel pressure is ok. Na try din namin ibleed. Ayaw pa din
    What was the pressure the pump was giving?
    Apr 2014
    According to the mechanic of kia(casa) fuel pressure is ok pero wla silang device to measure it
Help! Car wont start OBD P0685.
