Results 1 to 20 of 22
    Apr 2014
    Good morning!
    Patulong sana sa problem ng Kia Carnival 08. Car wont start. OBDII reading is P0685.
    ECU/PCM power relay curcuit open. 1 1/2 months ba nka garahe ung van.
    Thanks!
    Quote Originally Posted by Paul77 View Post
    Good morning!
    Thanks!
    Potential causes for this code to set are:
    A defective PCM power relay
    A blown fuse or fusible link Corroded or damaged wiring or wiring connectors (especially near the PCM relay)
    Faulty ignition switch
    Partially or totally disconnected electrical terminal at the ignition switch
    Loose or corroded battery cable ends
    Read more at: P685 ECM/PCM Power Relay Control Circuit Open
    Copyright OBD-Codes.com
    Apr 2014
    Read more at: P�685 ECM/PCM Power Relay Control Circuit Open
    Main relay and fuse are ok.
    Battery is 1month old. Cleaned the terminals already.
    Ung engine nag ccrank pero d lng mag start. Parang mag sstart na ung crank nya
    How's the batt?
    Batt sir is new. Last oct lng nag palit.
    How's the batt?
    Check the Main relay
    when you look into the abyss, the abyss looks into you
    Apr 2014
    Main relay is ok. Abyss?
    Check fuel pressure....if low or none, proceed to filter, then pump.
    Apr 2014
    Fuel pressure is ok. Na try din namin ibleed. Ayaw pa din
    What was the pressure the pump was giving?
    Apr 2014
    According to the mechanic of kia(casa) fuel pressure is ok pero wla silang device to measure it
    Reason I asked coz I've encountered failing pumps that still worked but gave pressures too low to fire engine up. Most injector rails have a Schrader valve for fuel gauge hook up. This helps eliminate suspects clearly. Some filter assemblies have a pressure regulator, too. If there is & it's faulty, the pressure reading would be low, too. Should fuel distribution check out, proceed to ground, harness & contact investigation. Cars in hibernation are a rodent fave. Check for chafed & split wires....this part I hate.[emoji852]
    Jan 2018
    tune up first......
    Jun 2008
    Anong sasakyan?
    Sent from my NX549J using Tsikot Forums mobile app
    Apr 2014
    Quote Originally Posted by weisshorn View Post
    Anong sasakyan?
    Kia carnival 08 sir
    So d sya lalabas sa OBD na failing fuel pump? Or preasure is too low?
    Kia carnival 08 sir
    Hit or miss, some failing pumps won't pop any code.
    Jan 2009
    The DTC points to a power supply issue that is either external or internal to the ECM/PCM. It's pretty far from being a fuel supply issue, isn't it?
    Batt charge drops w/ all the crank attempts....& when it does, all sortsa random DTCs can pop. Have seen 1 case w/ a TCM code. Car cranked & started up fine but ran rough. Had the batt health checked, twas on its way out, but had enough juice left not to show signs. Cleared the code, same would re-pop. A day after, car's gauge needles would just sweep. Car failed to fire up. The only code extracted was for the same tranny fault. Re-cleared the code, swapped a new batt in.....car ran like new w/ no hiccups nor codes.
    On huntdowns, a code reader is handy, but I would never downplay shared experience. A thorough elimination process, from easiest & least cost going up, will help pin this....There will be no harm checking fuel distribution to rule it out. Just my humble 2cents, good sir.[emoji4]
    Jan 2008
    Kia carnival 08 sir
    Na check mo na ba kung may kuryente sa mga injectors while cranking? Check mo din wires papunta sa ecm/pcm baka may kagat ng daga
Help! Car wont start OBD P0685.
