Results 1 to 10 of 22
- Apr 2014
- 13
December 8th, 2017 11:45 AM #1Good morning!
Patulong sana sa problem ng Kia Carnival 08. Car wont start. OBDII reading is P0685.
ECU/PCM power relay curcuit open. 1 1/2 months ba nka garahe ung van.
Thanks!
- Nov 2009
- 3,484
December 8th, 2017 01:52 PM #2Potential causes for this code to set are:
A defective PCM power relay
A blown fuse or fusible link Corroded or damaged wiring or wiring connectors (especially near the PCM relay)
Faulty ignition switch
Partially or totally disconnected electrical terminal at the ignition switch
Loose or corroded battery cable ends
Read more at: P 685 ECM/PCM Power Relay Control Circuit Open
Copyright OBD-Codes.com
December 8th, 2017 04:29 PM #4
Check the Main relay
when you look into the abyss, the abyss looks into you
- Apr 2014
- 13
December 11th, 2017 12:41 PM #5
Main relay and fuse are ok.
Battery is 1month old. Cleaned the terminals already.
Ung engine nag ccrank pero d lng mag start. Parang mag sstart na ung crank nya
Batt sir is new. Last oct lng nag palit.
- Apr 2014
- 13
December 11th, 2017 12:43 PM #7
Check fuel pressure....if low or none, proceed to filter, then pump.
- Apr 2014
- 13
December 11th, 2017 12:58 PM #8
December 11th, 2017 01:02 PM #9
- Apr 2014
- 13
December 11th, 2017 01:34 PM #10
Xiaomi E-Car
