Results 31 to 40 of 51
September 14th, 2006 04:51 AM #31
September 14th, 2006 07:06 AM #32
September 14th, 2006 08:00 AM #33
MF batteries doesn't corrode in the terminals anymore. kaya sobrang ok nga mga MF batts, maintenance free talaga.
September 14th, 2006 08:17 AM #34
Dati nagtipid ako, bought the usual maintenance full battery kasi almost 1/2 ang difference niya. kept on checking the water level and eventually got tired of doing so as there seems to be no change in the level. Suddenly the battery went kaput. Had it check in my suking battery outlet. Turns out the plates were all dried up...it was within the warranty period but I forgot to check the level before bringing it to the shop. Ended up voiding the warranty and buying a new one, a maintenance free one.
September 14th, 2006 09:12 AM #35
Kasama ba sa PMS ang battery check? Kung tama ang water level or kung mahina na ang baterya.
September 14th, 2006 09:38 AM #36
It should be. Because PMS involves checking all vehicle fluid levels (pati washer fluid).
Kung nag-aasin sa terminal, binubuhusan ko lang ng tubig. hehehe. Ano nga ba dapat nilalagay dun para hindi mag-asin? Vinegar ba? Sorry, I can't remember. Household remedy lang yun.
September 14th, 2006 02:15 PM #37
September 14th, 2006 03:01 PM #38
anong brand po ba magandang conventional battery? at gaano katagal kaya lifespan ng mga conventional batts?
Tsikot Member Rank 4
- Jun 2006
- 2,605
September 14th, 2006 05:52 PM #40
Ayun, baking soda nga. Thanks!
i wonder, are the usual published suspension adjustment specifications supposed to be adjusted...
Wheel Alignment
