^^ ano ba yung question ni ferdie444? anyways, kung ok yung car mo before the alarm installation, you can pressume na iyon na nga ang problem kyung bakit nag i stall ride mo... but i think its a very rare occassion kasi wala naman direct connection ang alarm sa engine except yung starter killer switch/relay..baka me nagalaw lang na mga wires when it was installed.
it just gave you the answer to your question. the battery terminal has high resistance under load. clean the corrosion and protect the now clean terminals with terminal sealant or vaseline to seal against oxygen
Quote Originally Posted by joey roo View Post
Normally kapag umiinit ang wire, either overloaded or loose ang terminal. But in your case, tingin ko wala ka namang additional heavy electrical load which will cause the abnormal temperature of wire. So its the terminal connection of the battery. Pero dapat hindi lang yung wire ang mainit, pati na rin yung terminal post. Kung hindi naman mainit yung terminal post, maybe you have a loose connection somewhere after the battery terminal.
follow these suggestions and you will never go wrong...
