Quote Originally Posted by erik081200 View Post
Hello everyone!
I have this car problem. Bigla na lang namamatay auto kapag full load. Naka-on aircon, ilaw, stereo. Nangyayari ito kapag nag-preno ako or shift lights from low to high beam. Iilaw muna battery warning light sa front panel then stop na makina. Parang di kaya additional load but when I re-start it, OK naman ulit.
Sa tingin ko hindi battery or alternator. And another thing, napansin ko sobrang init ng negative pole ng battery ko pero hindi naman masyado maiinit battery. Ano po kaya problem nito. May car is Honda 95 model. Thanks in advance and God bless.
The hot terminal explains it all. There is excessive resistance at your battery terminal. At high electrical loads, the car would get the extra electricity from the battery. Since your car can't get enough power from the battery, it tried to get it directly from the alternator. Since there is not enough power to go around between the engine and the rest of your electrical loads, the engine dies.
Solution is to check if the terminal is still in good condition. If yes, just clean the contact areas and fasten it securely.
