Results 41 to 50 of 82
January 16th, 2010 12:33 PM #42
- Mar 2009
- 81
October 28th, 2011 11:27 PM #43Guys ask lang. im new lang sa tech. I have an innova, gusto ko sana ikabit ung 2 set bosch europa ko. Panu ba gagawin ko?
1. OK lang ba yung stock wire and relay ko and just put the 2 set of new horn (male to female plug, yung stock lang gamit)
2.nid pang palitan yung wires and relay?
October 30th, 2011 01:57 AM #44
The original horn wiring of your car was not designed to handle the current that the Bosch Europa will draw. If you just replace your original horns with the Europa's there is a good chance that you will fry your wiring.
It's been a while since I installed mine but use a different relay (normally open).
Then use the original wiring and connect it to the switch inputs of the new relay. Connection 85 if I'm not mistaken. Please refer to the diagram provided by Madox.
November 1st, 2011 08:23 PM #46
Buhayin ko lang tong thread na to...
Tanong ko lang ayos ba yung groundings ng bosch europa silver ko hindi naka tap yung groundings sa bracket nung horn direkta siya sa negative grounding ng battery pero ayos naman wala naman nagiging problem.
- Aug 2014
- 4
August 16th, 2014 04:57 AM #47Mga sirs question about bosch europa silver. Kaya ba imount sa likod ng mesh ng bumper or sa grille? If pede sa bumper, kelangan ba baklasin or pedeng hindi na?
- car is honda jazz ge 1.5v(facelift)
Thanks in advance.
- Nov 2014
- 2
November 22nd, 2014 02:33 AM #48mga sir newbie here, i just bought bosch europa black series at plano ko ilagay sa fortuner ko, un nga lang d ko nga maikabit pa dahil naguguluhan pa ako sa procedures. anyway may relay narin po ako, baka pwde po mkahingi ng clear tips and advice sa installation at kung anung mga parts pa ang needed. thanks in advance po sainyo
November 22nd, 2014 03:17 PM #49
Well looks like they're gonna make it easier na to transfer ownership. Timely since I need to...
transfer of ownership / registration cost
