Results 61 to 70 of 82
- Apr 2010
- 739
October 10th, 2017 12:24 PM #61Sorry wala akong diagram, there are lots of them available online. Di ko na rin matandaan exact pinouts (parang 85,86,30 ata on a standard Bosch 5-pin)
The relay trigger should be wired to the previous horn's connector
Fuse the +12Vdc connection going from the battery to the relay, ideally the fuse should be as close to the battery as possible
The earth/ground pin can be connected on the body ground
The output pin goes to your new horns
October 10th, 2017 12:33 PM #62
- Mar 2014
- 63
August 30th, 2018 08:44 AM #64
- 52,523
August 30th, 2018 08:52 AM #65looking at the picture above, i would put a couple of fat washers there, and i wouldn't need that shiny bracket.
i've done it before, and it works, long-term.
if you are handy with your hands, and you have some scrap metal, and you have some basic tools around, you can make them yourself, po.
no one will see them under the hood, so they do not have to be as beautiful as ninja's.
but any half-decent metal work place can do it for you in a jiffy, even "while you wait", if their shop isn't too busy..
but be mindful of the post-work painting. these iron pieces can rust pretty fast, especially if acetylene had been used...
aluminum works, and does not require post-work painting, because it does not rust.
but they would have to be thicker than the equivalent iron ...
but do you really need mounting brackets?
ang daming butas diyan sa likod ng front grille at sa harap ng radiator...
i remember mounting horns in our cars, without the need for additional mounting brackets other than what the new horn came with. it's not illegal to bend these brakets.
also, find out if you need a ground, and act accordingly.
good luck.Last edited by dr. d; August 30th, 2018 at 09:57 AM.
- May 2018
- 39
January 2nd, 2019 12:26 PM #66when ba need mag lagay pa ng relay? or is relay optional lang talaga to improve sound?
January 2nd, 2019 12:42 PM #67
- 52,523
January 2nd, 2019 04:31 PM #68
April 7th, 2019 05:48 AM #69
may naka try na ba install europa along with stock horns?
medyo naguluhan ako sa layout eh
August 20th, 2019 04:49 AM #70
the triumph of man over... man!, using the crudest of implements (by modern standards).
Traffic!
