Page 47 of 115 FirstFirst ... 374344454647484950515797 ... LastLast
Results 921 to 940 of 2297
    #921
    Quote Originally Posted by trucker111 View Post
    any feedback on amaron pro?
    price?
    Last time I called Metrobat mas mataas ng 1K ang 2SMF Pro 75 Amp * 5,600, kaysa 2SMF Hi Life 65 Amp * 4,600 as of 7/24/14
    Sep 2009
    #922
    may naka experience na sa inyo ng medyo ilang seconds starting pag malamig panahon? yung parang hard starting?
    di ko na-experience sa motolite yung ganito.
    Aug 2004
    #923
    So far wala naman. More than 1 year na pala ang 1SN namin and parang bago pa rin ang redondo. Check mo terminals baka maluwag or madumi.
    May 2013
    #924
    Quote Originally Posted by holdencaulfield View Post
    I've read a couple of feedbacks from other Amaron owners, re the slight hard starting on cold temperature, and I think thats the achilles' heel of Amaron. That's the "only?" advantage of Motolite, against Amaron. But I think the hard starting tends to be 1-2 seconds longer than normal only. I don't know if may effect yun on other parts of the engine like, alternator, starter etc.
    May 2013
    #925
    Jul 2011
    #926
    Nung pumunta ako ng cebu almost 1 month naka park lan un car, sa unang start ko walang redondo, then off ko ulit, pag start ko nag redondo naman pero medyo mataas rpm, pero after that wala naman kakaiba.
    Sent via LaTE Network
    Sep 2009
    #927
    nangyari ulit! this time akala ko hindi na magstart. left the car unused for two days due to typhoon. this morning, the weather here in caloocan is colder than usual and the air is misty(or smoggy).
    the first time this month my car got blanketed with dew and i could say it's really cold.
    pag start ko, ang tagal ng redondo tapos nung bumuga na yung kuryente, ang baba ng rpm parang naghahabol yung makina.
    yung mga motolite ko, walang panahon na nangyayari yung ganito. feeling ko baka kung mag baguio ako baka hindi kayanin ni amaron yung lamig.
    and malinis mga terminals ko, sinasabay ko pag naglinis ako ng tenga.
    Apr 2014
    #928
    So far amaron battery is still good here. May kanya kanya talaga takbuhan ng amaron as per area hehe. Good to hear they're spreading.
    May 2013
    #929
    I'm somehow sure na mahihirapan ang Amaron, when you go up to baguio. Most comments i read are either from there or visited that place and found it hard starting. Most i read was, it takes 3 cranks before it started, this on a diesel engine though.
    Apr 2012
    #930
    Wala ako problema sa Amaron kahit nung umakyat ako ng foggy weather ng Tagaytay
    Jan 2012
    #931
    2 years na yung amaron ko sa jazz ayun ok na ok pa din. had it tested sa honda pampanga pasado. good pa sya. registered 12.9.
    #932
    Sana dumami pa network ng amaron at bumaba ulet presyo nya.
    Aug 2004
    #933
    15 months old na pala ang Amaron ng Vios namin. Because of the holidays di sya nagamit for one week. Started right up with no problems yesterday.
    #934
    because of holidays or new car?
    Aug 2004
    #935
    Both
    #936
    Joining this thread now. Got a 3SMF R Hi Life yesterday with 21 months warranty.
    Off the bat, grabe ang weight difference ng Amaron sa Motolite Gold na pinalitan. Pinasubok sa akin ni manong. Totoo nga!
    Ang lutong ng cranking. Used it for the whole day yesterday, and for about 3 hours with the engine off while I was cleaning the interior plastic bits of the GS and watching Top Gear. Lutong pa din.
    Hopefully tumagal.
    Aug 2009
    #937
    size of amaron battery for ford e150 2003 model? reverse
    mayroon ba malapit sa batasan area? contact and other dtails thank u
    #938
    Took the GS to Baguio over the weekend. No issues with the 10-15 degree mornings. Malutong at malakas ang pag-crank!
    Finally my suking auto shop has amaron battery. P6,500 for 3SMF N70, not bad considering almost same prize as motolite gold 21months MF.
    Aug 2010
    #940
    P6.5k is high. tawaran mo or look for other dealer.
    i bought mine P5.1k (amaron hi-life) kasama trade in.
Amaron battery
