Results 11 to 11 of 11
April 12th, 2014 08:34 AM #11
thank you po sa guide sir
napapansin ko din po yung #1 SP nababasa. possible cause ay yung o-rings nito baka need na mapalitan. but the fuel consumption i have stays the same (10-11kms per liter city driving). di po kasi ako mahilig sa racing mode.
though may times na parang hirap yung engine wether the a/c is on or off. parang may slight palyado but i release the gas pedal and step again, ok na
di ko po masasabi na slightly elevated engine temp gawa ng rekta po kasi mga fan. yung a/c po naka-rekta na din. baka isa din itong cause. i may need to replaced the compressor as the one installed is still the original part oem. will have it checked and hingi ako ng estimate kung magkano abutin pag ibinalik sa dating levers.
bagong palit po yung alternator (2nd hand surplus) to 90 amperes. 14 sa battery meter and pag on ang a/c with headlights and radio, nasa 13.5 po sya. as per electrician, ok ang load.
Have good situational awareness. But even then, you cannot anticipate everything. When it's your...
