Page 1 of 3 123 LastLast
Results 1 to 10 of 21
    Jun 2006
    ANo dapat gawin kapag ayaw gumalaw ng needle sa odometer? Ok naman sya nung gamit ko kotse pero nung pauwi na ako ay ayaw na gumalaw ng needle...ano problem dito?
    May 2007
    Quote Originally Posted by jonski View Post
    Odometer needle......or speedometer?
    Jun 2006
    Speedometer cable / whatever links the tranny and speedo?
    Jun 2006
    Quote Originally Posted by v6dreamer View Post
    speedometer
    May 2007
    If all the other gauges work and that is the only gauge that is not working then most likely suspect a bad speed sensor or maybe a loose connection at the speed sensor.
    Your Speed Sensor should be where your right axle shaft goes into your transaxle. The tranny has 2 sensors input & output 1 or both may be bad. You may have to replace both.
    siguro bro sabihin mo muna kung ano ang year/model info ng ride mo.
    pag sensor type, pwedeng sensor or wiring or yung actual instrument cluster
    pag manual type, pwedeng cable o yung gear
    Aug 2006
    Pag honda 92 to 2000 model, facing the engine nasa left side below the throtlle body.
    Pag toyota naman, facing the engine right side below the throttle body.
    both are attach sa tranny
    HTH
    magkano aabutin sa sensor?
    Ano kayang problema kapag iyong digital odometer display Ng kotse hindi agad namamatay after I -deactivate Ang ignition? Siguro mga 20-30 seconds pa bago mawala iyong display?
    Mirage Pala iyong car.
0dometer problem
