Results 1 to 20 of 21
    Jun 2006
    ANo dapat gawin kapag ayaw gumalaw ng needle sa odometer? Ok naman sya nung gamit ko kotse pero nung pauwi na ako ay ayaw na gumalaw ng needle...ano problem dito?
    May 2007
    Quote Originally Posted by jonski View Post
    Odometer needle......or speedometer?
    Jun 2006
    Speedometer cable / whatever links the tranny and speedo?
    Jun 2006
    Quote Originally Posted by v6dreamer View Post
    speedometer
    May 2007
    If all the other gauges work and that is the only gauge that is not working then most likely suspect a bad speed sensor or maybe a loose connection at the speed sensor.
    Your Speed Sensor should be where your right axle shaft goes into your transaxle. The tranny has 2 sensors input & output 1 or both may be bad. You may have to replace both.
    siguro bro sabihin mo muna kung ano ang year/model info ng ride mo.
    pag sensor type, pwedeng sensor or wiring or yung actual instrument cluster
    pag manual type, pwedeng cable o yung gear
0dometer problem
