Results 1 to 10 of 21
March 21st, 2009 12:29 AM #1
ANo dapat gawin kapag ayaw gumalaw ng needle sa odometer? Ok naman sya nung gamit ko kotse pero nung pauwi na ako ay ayaw na gumalaw ng needle...ano problem dito?
March 22nd, 2009 05:00 AM #5
If all the other gauges work and that is the only gauge that is not working then most likely suspect a bad speed sensor or maybe a loose connection at the speed sensor.
Your Speed Sensor should be where your right axle shaft goes into your transaxle. The tranny has 2 sensors input & output 1 or both may be bad. You may have to replace both.
THE AUTO SPECIALIST
- Mar 2006
- 607
March 22nd, 2009 09:29 AM #7
pag sensor type, pwedeng sensor or wiring or yung actual instrument cluster
pag manual type, pwedeng cable o yung gear
March 22nd, 2009 06:51 PM #8
Pag honda 92 to 2000 model, facing the engine nasa left side below the throtlle body.
Pag toyota naman, facing the engine right side below the throttle body.
both are attach sa tranny
HTH
- 199
May 20th, 2025 03:38 PM #10
Ano kayang problema kapag iyong digital odometer display Ng kotse hindi agad namamatay after I -deactivate Ang ignition? Siguro mga 20-30 seconds pa bago mawala iyong display?
Mirage Pala iyong car.
repair kit lang. car care nut says, for toyotas, he recommends entire assembly replacement for...
rack and pinion repair
