ANo dapat gawin kapag ayaw gumalaw ng needle sa odometer? Ok naman sya nung gamit ko kotse pero nung pauwi na ako ay ayaw na gumalaw ng needle...ano problem dito?
If all the other gauges work and that is the only gauge that is not working then most likely suspect a bad speed sensor or maybe a loose connection at the speed sensor.
Your Speed Sensor should be where your right axle shaft goes into your transaxle. The tranny has 2 sensors input & output 1 or both may be bad. You may have to replace both.
pag sensor type, pwedeng sensor or wiring or yung actual instrument cluster
pag manual type, pwedeng cable o yung gear
Pag honda 92 to 2000 model, facing the engine nasa left side below the throtlle body.
Pag toyota naman, facing the engine right side below the throttle body.
both are attach sa tranny
HTH
Ano kayang problema kapag iyong digital odometer display Ng kotse hindi agad namamatay after I -deactivate Ang ignition? Siguro mga 20-30 seconds pa bago mawala iyong display?
Mirage Pala iyong car.
As long as namamatay after a few seconds, that's normal. It's a feature on many cars.
Seems like it's normal. You can use that period to reset the service interval warning light.
https://www.youtube.com/watch?v=SQCILo-Q4qs
Buti nga yung dashboard lang. Yung sa Ford Everest 2011 (not sure if same pa rin sa latest model nila), after mo ma off yung susi, naka ON pa rin sasakyan kahit nasa labas kana ng car. Mag OFF lang yung andar after 30s ata or less than a minute ba yun.
Kaya nga boss, if turbo timer feature talaga yang naobserve ko sa Everest, Im hoping default feature sana to sa lahat ng naka turbo na sasakyan.
OK lang if tayo lang ang gumagamit ng sasakyan, hintayin talaga mag cool off before turning off engine from long drive.
If si misis yung nag drive, automatic off agad kahit from long drive.
