Results 1 to 10 of 33
- Dec 2011
- 7
December 11th, 2011 06:58 PM #1sa lahat po ng may optra 2006 model...tanong lang po may nabili kc kami last month...may talsik ba talaga sa deep stick sa engine nya/?thank po
- Jun 2011
- 251
December 11th, 2011 07:53 PM #2saan po location nyo sir?
we do overhaul po at complete overhaul ng optra. LS/LT
pwede rin po kami home service po.
pwede ko po kayo qoute on the spot pag makita ko yung oto,
09164709860
544-17-14
- May 2011
- 481
December 11th, 2011 08:09 PM #3whoa! easy wielding the "overhaul" idea. check the basics first. it might be just a stuck pcv valve. have a compression test, engine cranking vacuum and engine idling vacuum test and a cylinder leakage test done first. the optra model is only a few years old and maybe the mileage does not even warrant an overhaul.
- Dec 2011
- 7
- Dec 2011
- 7
December 12th, 2011 10:11 AM #5at 37k palang tinakbo..ok naman..wala naman check engine,,,run smooth...kaya lang bakit may talsik sa deep stick?
- Dec 2011
- 7
- Jan 2008
- 4,726
December 12th, 2011 11:52 AM #8sorry pero dami talaga dumb pag dating sa sasakyan.. saan ba sa manual nyo nabasa na dapat buksan ang oil cap at dip stick habang umaandar ang makina?? syempre umaandar ang makina at meron yan moving parts at pressure habang umaandar kaya talagang tatalsik ang langis nyan...
- Dec 2011
- 7
December 12th, 2011 12:03 PM #9worry lang kasi si sister..sa nabili nya,,kc sa honda at mga others cars,,sbi nila pag may talsik blowbye na makina..
- May 2004
- 903
December 12th, 2011 12:39 PM #10Hindi naman 100% na Blow by na.. when buying 2nd hand car pag may ganoong symptoms eh iwasan na lang.. not unless pumayag yung seller na pa check sa shop yung sasakyan where you can perform compression test.... And ingat din sa pag bukas ng oil filler cap kasi one time pag bukas ko sumirit yung oil buti na lang nakaiwas ako agad...
If you don't have a spare tire, a tire inflator using the socket of the car as power outlet is the...
Liquid tire sealant
