Page 1 of 4 1234 LastLast
Results 1 to 10 of 33
    Dec 2011
    sa lahat po ng may optra 2006 model...tanong lang po may nabili kc kami last month...may talsik ba talaga sa deep stick sa engine nya/?thank po
    Jun 2011
    saan po location nyo sir?
    we do overhaul po at complete overhaul ng optra. LS/LT
    pwede rin po kami home service po.
    pwede ko po kayo qoute on the spot pag makita ko yung oto,
    09164709860
    544-17-14
    May 2011
    whoa! easy wielding the "overhaul" idea. check the basics first. it might be just a stuck pcv valve. have a compression test, engine cranking vacuum and engine idling vacuum test and a cylinder leakage test done first. the optra model is only a few years old and maybe the mileage does not even warrant an overhaul.
    Dec 2011
    sabi ni mang mario...normal lang daw sa mga optra un...?
    Dec 2011
    at 37k palang tinakbo..ok naman..wala naman check engine,,,run smooth...kaya lang bakit may talsik sa deep stick?
    Oct 2011
    ano ung talsik sa dipstick?
    Dec 2011
    ung langis po nya'''pag binuksan mo may tatalsik na langis..
    Jan 2008
    sorry pero dami talaga dumb pag dating sa sasakyan.. saan ba sa manual nyo nabasa na dapat buksan ang oil cap at dip stick habang umaandar ang makina?? syempre umaandar ang makina at meron yan moving parts at pressure habang umaandar kaya talagang tatalsik ang langis nyan...
    Dec 2011
    worry lang kasi si sister..sa nabili nya,,kc sa honda at mga others cars,,sbi nila pag may talsik blowbye na makina..
    May 2004
    Quote Originally Posted by garythyron View Post
    Hindi naman 100% na Blow by na.. when buying 2nd hand car pag may ganoong symptoms eh iwasan na lang.. not unless pumayag yung seller na pa check sa shop yung sasakyan where you can perform compression test.... And ingat din sa pag bukas ng oil filler cap kasi one time pag bukas ko sumirit yung oil buti na lang nakaiwas ako agad...
optra?
