Results 1 to 10 of 75
- Jun 2011
- 251
July 2nd, 2011 08:48 PM #1for all owners of
CHEVY OPTRA LS 1.6 DOHC E-TECH 2
we do complete overhaul and top overhaul.
we have our own optra ls 1.6 dohc.
from piston, piston liner or sleeve, piston rings, engine valve,valve guide, valve seal,lapping, oil seal,head gasket, intake and exhaust gasket, pcv valve(the hardest to find). rear oil seal.
and the crucial timing and the most hardest to determined for most mechanic outside casa,
we already knew where to find these product, most of them are not available in thunder. even casa for PCV valve which is only 60,000 kms and need to be repalce.
here some quotation:
valve seal : 2450
valve guide : 1350 sets
engine valve : 650 each
head gasket: 1350 orig
camshaft oil seal: 280 each orig
PCV valve: 1200 orig
piston liner or sleeve : 1200 each plus 4000 labor for machine shop.
Ignition coil: OEM php 3500
labor:
top overhaul (or dukot).
php 4700
plus machine shops labor:
we can buy your parts or you.
3 to 5 days depending on machine shop availability
complete engine overhaul:
from valve seal piston rings, camshaft, throttle body cleaning, all gasket replace and oil ring replace
php 8500
plus machine shop labor.
5 to 8 days depend on machine shop availability.
PCV VALVE valve last only for 60,000 kms.
its only php1200.orig
the chevy optra timing is crucial if the mechanic will do it for the first time is so confusing,
and if he's not sure your engine valve get bend (550 each x 16pcs + machine shop labor +valve guide php1350)
we allready encounter bend engine valve (optra) due to timing.
php 25,000 all in all.
we do home service for your optra.
depends on how far from our shop in cainta.
txt or call us:
09164709860
for parts 50% down and 50% upon delivery.
tnx guys
- Jun 2011
- 251
July 8th, 2011 11:51 PM #2our first optra complete overhual
from qc talyer pinasa samin
from this........
to this.....
now.... another one.
from chevy pasig c-5
complete ovehaul
busted oil pump.. 4,000 orig
rear, front ,oil pump gasket.. need to be replace
cylinder head gasket, oil sender, valve seal, piston ring.
need to be replace...bearing....
busted PCV VALVE , alot of additives , busted oil pump...
will update when we put this back together... 07/08/2011
- Oct 2008
- 59
- Jun 2011
- 251
July 11th, 2011 12:14 AM #4
- Jun 2011
- 251
August 15th, 2011 06:58 PM #5wala na nga pala kami sa bonifacio drive pinapagawa ko pa yung shop namin ngayon sa may cainta.
new price:
segunial/ crangkshaft 28,000 brand new 5 days delivery
con rad arm 6,500 brand new
computerbox matic 30,000 surplus 1.6 ls matic
computer box lt 35,000 brand new for LT 1.8 matic
transmission box 25,000 brand new for LT 1.8 matic
pm me :
- Jun 2011
- 251
- Jun 2011
- 251
September 3rd, 2011 10:52 PM #7update ko kayo sa optra LT 1.8 automatic na ginagawa namin
labor material is 78k plus another 58k ...
grabe ba ang presyo.
eto ang papalitan
tcm
repair ecu
solenoid valve shifter
transmission assembly automatic
power steering pump
timing belt sets
etc...
ondoy victim pa to....
- Oct 2009
- 11
September 11th, 2011 01:51 AM #8Sir, ung optra ko lagi namamatayan and laging parang palyado. AT transmission sya. My idea kyo kung ano problema. Need help salamat.
- Jun 2011
- 251
October 2nd, 2011 04:20 PM #9depende yan sir kung ano yung datong pinagawa nyo before cya magkaroon ng problemang ganyan.
pwede sa timing kaya palyado or sa throttle body nya.
pwede rin sa ignition coil...
txt me boss para madala nto sa talyer namin.
09164709860
- Jun 2011
- 251
October 2nd, 2011 04:24 PM #10may talyer na po pala kami....
eto address
155 marick drive, marick subdivision cainta rizal
from junction galing ng ortigas
take right papuntang cainta proper then take first right ulit sa may rural bank
tapos pang apat na lot mula sa kanan
bagong talyer namin
medyo di pa tapos pero may bubung na
txt us before visiting para naman maka paghanda kami
puro kasi service kami ngayon last time sa tiaong quezon.
09164709860
A 70/30 water to coolant mix may improve cooling efficiency but that's at the cost of less...
Coolant...
