Page 2 of 2 FirstFirst 12
Results 21 to 40 of 75
    Aug 2009
    sir paquote po, optra chev 06 pa 60,000 km maintenance. palit timing belt at ung mga dapat palitan na. how much po ksma parts at labor? molino bacoor cavite location pahome service. thank you
    Jun 2011
    Quote Originally Posted by weszt View Post
    paki txt nalang po ako pag usapan natin.
    09277555272
    Aug 2009
    sir pm nyo po ako
    - - - Updated - - -
    sir pm nyo po ako
    Aug 2009
    Sir tanong, aabot p kaya kng ung timing belt eh pag lagpas n ng 60000km papalitan 2006 optra sir. 55,000km p lng po odo ko.
    balak ko dalhin sa ilocos this feb.
    Aug 2009
    salamat sa pagchange ng timing belt mike.
    Aug 2010
    BIGGER AND STRONGER! JOIN US! ChevroletClub Philippines Inc.
    To learm more about us you may visit our Facebook page (About ChevroletClub Philippines Inc.)
    Club Group Page (OPTRA Group)
    Latest Club EB: Nuvali- Wake Park EB - 01.20.2013 "Nice place, Great Company "
    Aug 2009
    imageuploadedbytsikot-car-forums1387626325.512708.jpgimageuploadedbytsikot-car-forums1387626325.512708.jpgimageuploadedbytsikot-car-forums1387626349.128853.jpg
    Sent from my iPhone using Tsikot Car Forums
    Feb 2014
    What is the number I can call u? no response on 09277555272 ..tks
    Dec 2014
    Hi sir my bro bought an optra AT 2014 last oct tpos iniwan nya sa akin ksi ofw cia n kaka encouter kmi engine stalling habang nagdadrive ka bigla mawawalan power engine, eletrical stops completely while in the middle of driving may na encounter na po ba kio ganito issue ano po recommendation nio tnx sir
    Sep 2013
    good day sir, yes po naecncounter nanamin same trouble before, worst pa eh walang check engine so wala kang pwedeng ihatol na palitan at hirap explain bakit kailangan palitan,
    pag start normal, idle normal, even aircon or drive anjd reverse position sa automatic transmission ay no problem, pero bigla lang cya namamatay, kahit natakbo or naka park lang.
    question muna para ma evaluate;
    1. hard starting ba pag malamig, like di cya kaya ng isang start lang, second start or more bago sya dumeretso na start/
    2. pag mamamatay na cya eh nararamdaman mo ba na paunti-unti baba ng idle/
    3. pag nag shut down ba sya eh may lalabas na check engine pero pag start eh ok na cya ulit, or mababa nja ang idle di kaya pag naka aircon..
    4. ano po huling pinagawa nyo before cya magtampo hehehe.
    5. may pina convert, dagdag, pinabago sa kanya, like compressor conversion, aux fan na direct ikot agad pag on ang susi, HID,alARM, etc.
    post mo sir para mabasa din ng iba na same problem.
    sa 1 out of 30 unit na pumapasok sa amin same problem.
    Quote Originally Posted by Erwin Colis View Post
    Mar 2015
    Thanks mikehunter.
    Oct 2015
    Quote Originally Posted by mikehunter1980 View Post
    for all owners of
    CHEVY OPTRA LS 1.6 DOHC E-TECH 2
    we do complete overhaul and top overhaul.
    we have our own optra ls 1.6 dohc.
    from piston, piston liner or sleeve, piston rings, engine valve,valve guide, valve seal,lapping, oil seal,head gasket, intake and exhaust gasket, pcv valve(the hardest to find). rear oil seal.
    and the crucial timing and the most hardest to determined for most mechanic outside casa,
    we already knew where to find these product, most of them are not available in thunder. even casa for PCV valve which is only 60,000 kms and need to be repalce.
    here some quotation:
    valve seal : 2450
    valve guide : 1350 sets
    engine valve : 650 each
    head gasket: 1350 orig
    camshaft oil seal: 280 each orig
    PCV valve: 1200 orig
    piston liner or sleeve : 1200 each plus 4000 labor for machine shop.
    Ignition coil: OEM php 3500
    labor:
    top overhaul (or dukot).
    php 4700
    plus machine shops labor:
    we can buy your parts or you.
    3 to 5 days depending on machine shop availability
    complete engine overhaul:
    from valve seal piston rings, camshaft, throttle body cleaning, all gasket replace and oil ring replace
    php 8500
    plus machine shop labor.
    5 to 8 days depend on machine shop availability.
    PCV VALVE valve last only for 60,000 kms.
    its only php1200.orig
    the chevy optra timing is crucial if the mechanic will do it for the first time is so confusing,
    and if he's not sure your engine valve get bend (550 each x 16pcs + machine shop labor +valve guide php1350)
    we allready encounter bend engine valve (optra) due to timing.
    php 25,000 all in all.
    we do home service for your optra.
    depends on how far from our shop in cainta.
    txt or call us:
    09164709860
    for parts 50% down and 50% upon delivery.
    tnx guys
    boss may available po ba kayo cylinder head gasket para sa chevy optra 06? salamat po. 0-9-7-7-1-6-9-4-4-5-5
    Sir better answer the questions and not flooding the thread with your infomercial... IF NOT I WILL CLOSE THIS THREAD!
    THANK YOU.
    Nov 2015
    P
    for all owners of
    valve seal : 2450
    labor:
    php 4700
    php 8500
    txt or call us:
    09164709860
    tnx guys
    Boss. Pwede ako order ng head gasket for optra 1.6 LS
all owners of CHEVY OPTRA we do top ovehual and complete engine overhual.
