Page 1 of 4 1234 LastLast
Results 1 to 20 of 75
    Jun 2011
    for all owners of
    CHEVY OPTRA LS 1.6 DOHC E-TECH 2
    we do complete overhaul and top overhaul.
    we have our own optra ls 1.6 dohc.
    from piston, piston liner or sleeve, piston rings, engine valve,valve guide, valve seal,lapping, oil seal,head gasket, intake and exhaust gasket, pcv valve(the hardest to find). rear oil seal.
    and the crucial timing and the most hardest to determined for most mechanic outside casa,
    we already knew where to find these product, most of them are not available in thunder. even casa for PCV valve which is only 60,000 kms and need to be repalce.
    here some quotation:
    valve seal : 2450
    valve guide : 1350 sets
    engine valve : 650 each
    head gasket: 1350 orig
    camshaft oil seal: 280 each orig
    PCV valve: 1200 orig
    piston liner or sleeve : 1200 each plus 4000 labor for machine shop.
    Ignition coil: OEM php 3500
    labor:
    top overhaul (or dukot).
    php 4700
    plus machine shops labor:
    we can buy your parts or you.
    3 to 5 days depending on machine shop availability
    complete engine overhaul:
    from valve seal piston rings, camshaft, throttle body cleaning, all gasket replace and oil ring replace
    php 8500
    plus machine shop labor.
    5 to 8 days depend on machine shop availability.
    PCV VALVE valve last only for 60,000 kms.
    its only php1200.orig
    the chevy optra timing is crucial if the mechanic will do it for the first time is so confusing,
    and if he's not sure your engine valve get bend (550 each x 16pcs + machine shop labor +valve guide php1350)
    we allready encounter bend engine valve (optra) due to timing.
    php 25,000 all in all.
    we do home service for your optra.
    depends on how far from our shop in cainta.
    txt or call us:
    09164709860
    for parts 50% down and 50% upon delivery.
    tnx guys
    Jun 2011
    our first optra complete overhual
    from qc talyer pinasa samin
    from this........
    to this.....
    now.... another one.
    from chevy pasig c-5
    complete ovehaul
    busted oil pump.. 4,000 orig
    rear, front ,oil pump gasket.. need to be replace
    cylinder head gasket, oil sender, valve seal, piston ring.
    need to be replace...bearing....
    busted PCV VALVE , alot of additives , busted oil pump...
    will update when we put this back together... 07/08/2011
    Oct 2008
    saan ba shop ninyo?
    Jun 2011
    Quote Originally Posted by viraccat View Post
    saan ba shop ninyo?
    746 bonifacio ave bargy san juan cainta rizal. sa paradahan po ng G-liner at RRCG na bus sa cainta lagpas ng konti may shell gas station. tapat nun yung shop namin
    just call me kung pupunta kayo \
    09164709860
    Jun 2011
    wala na nga pala kami sa bonifacio drive pinapagawa ko pa yung shop namin ngayon sa may cainta.
    new price:
    segunial/ crangkshaft 28,000 brand new 5 days delivery
    con rad arm 6,500 brand new
    computerbox matic 30,000 surplus 1.6 ls matic
    computer box lt 35,000 brand new for LT 1.8 matic
    transmission box 25,000 brand new for LT 1.8 matic
    pm me :
    Jun 2011
    Jun 2011
    update ko kayo sa optra LT 1.8 automatic na ginagawa namin
    labor material is 78k plus another 58k ...
    grabe ba ang presyo.
    eto ang papalitan
    tcm
    repair ecu
    solenoid valve shifter
    transmission assembly automatic
    power steering pump
    timing belt sets
    etc...
    ondoy victim pa to....
    Oct 2009
    Sir, ung optra ko lagi namamatayan and laging parang palyado. AT transmission sya. My idea kyo kung ano problema. Need help salamat.
    Jun 2011
    depende yan sir kung ano yung datong pinagawa nyo before cya magkaroon ng problemang ganyan.
    pwede sa timing kaya palyado or sa throttle body nya.
    pwede rin sa ignition coil...
    txt me boss para madala nto sa talyer namin.
    09164709860
    Jun 2011
    may talyer na po pala kami....
    eto address
    155 marick drive, marick subdivision cainta rizal
    from junction galing ng ortigas
    take right papuntang cainta proper then take first right ulit sa may rural bank
    tapos pang apat na lot mula sa kanan
    bagong talyer namin
    medyo di pa tapos pero may bubung na
    txt us before visiting para naman maka paghanda kami
    puro kasi service kami ngayon last time sa tiaong quezon.
    09164709860
    Jun 2011
    shock absorber orig for optra ls 1.6
    3,500 each front
    550 stab link each
    oil change
    use only semi syn or fully syn.
    Jun 2011
    stock orig compressor
    1.6 ls
    php 14,000
    ***+++ pag kasama kabit 2,500 plus freon.
    orig po ito same ng quality at supplier ng casa
    09164709860
    544-17-14
    Jun 2011
    we have much lower price now and same quality
    call us
    09164709860
    09212474805
    5441714
    Jun 2011
    parts and labor update...
    pag kumatok sa overheat
    eto ang quotation di namin advise na hatakin ang optra ksi masisira yung ABS sensor sa bawat axle nya.
    pag metro manila ka lang' lets say sa QC nasa cainta yung shop na pagdadalhan.(shop namin)
    wrecker mga 5k malayo na yun.
    tapos kasama kami para ma check kung kumpleto ang pyesa at makita kung bakit ng overheat.
    may papers kaming pinapapirmahan na patunay na kinuha namin oto nyo pra i-service namin.
    noted natin yung mga sira or banga, or gasgas ng oto. etc.
    then need nyo mag down atleast ng 40% ng quote ko:
    magkano ba mostly ang quote pag ng overheat at kumatok? (yung pinaka worst)
    =wrecker 5,000
    =machine shop 13,600
    =overhauling gasket 6,500 orig
    =piston ring 5,000 orig
    =engine valve 550 each (pinaka marami na is 10pcs)
    =valve guide 1,250 orig
    =conrad arm 5,500 each
    =conrad bearing at main bearing(std to .50) 4,500
    =piston liner or sleeve 4,500 sets
    =timing belt sets (timing belt,tesioner,idler) 6,500 orig
    =outside belt or fan belt 1,250 orig
    =auto tensioner 3,200
    =spark plug GM 720
    =oil pump 3,200
    =water pump 2,500
    =oil filter 250 GM
    =crankshaft or segunial 18,000 bnew 3days wait.
    package QUOTATION :
    php 30k to 40k pg naputulan ng belt.
    php 40 to 50k pag overheat at kumatok * di po kasama ang segunial or crankshaft ha.
    php 50 to 75k pag may bali ang conrod, at palit ang segunial,
    *di po kasama ang bayad sa wrecker po ha.
    pag ngayon palang bubuksan ang makina at kumatok, minsan pwede pa yung segunial nya kung may tama depende lang ka kayod ng conrod at tama nya,
    standard size kasi ang orig. pwede pa sa .25 na bearing or .50 na bearing .sa casa ang sukat nila .25 is 10, .50 is 20 .75 is 30 wala pong .75 na bearing na.
    minsan may mga hinahatulan ang kasa na palit segunial na kasi ng 30 na or .75 na ang bearing.
    pag dinadala samin. try namin sa machine shop muna kung kaya pa. pag kaya (kadalasan) naka less agad kayo ng 18,000 petot.
    marami na kami nahatak sa casa.
    we have same supplier.
    call us feel free to ask
    09164709860
    Jun 2011
    [LIST=1][*]updated parts price. CASA PRICE: OUR PRICE:[*][*]timing belt 2,200 2,000[*]timing belt tensioner 1,933 1,400[*]idler 1,347 1,200[*]water pump 3,396 2,600[*]oil pump 3,416 2,000[*]radiator A/T 11,953 8,500[*]fuel pump 12,926 8,500[*]throttle body 12,124 10,500
    same parts same quality.
    same supplier
    same services plus more.
    Jun 2011
    Jun 2011
    post your question....
    or call us.
    [SIZE=4][SIZE=5]544-17-14 [/SIZE][/SIZE]
    Jun 2011
    clutch assembly
    optra 1.6
    10k
    labor 2.5k
    6hrs
    09164709860
    Jun 2011
    Jun 2011
    picture tom. para sa 1.6 at 1.8...
    1.8 LT parts
    timing belt set
    8,500 (timig belt,2pc idler bearing, tensioner)
    labor 2,500
    1.8 LT parts
    engine support 3,800 orig
    tranny support 3,600 orig
    engine support front 3,400 orig
    labor 1,200.
all owners of CHEVY OPTRA we do top ovehual and complete engine overhual.
