Results 21 to 30 of 75
Threaded View
- Jun 2011
- 251
July 2nd, 2011 08:48 PM #1for all owners of
CHEVY OPTRA LS 1.6 DOHC E-TECH 2
we do complete overhaul and top overhaul.
we have our own optra ls 1.6 dohc.
from piston, piston liner or sleeve, piston rings, engine valve,valve guide, valve seal,lapping, oil seal,head gasket, intake and exhaust gasket, pcv valve(the hardest to find). rear oil seal.
and the crucial timing and the most hardest to determined for most mechanic outside casa,
we already knew where to find these product, most of them are not available in thunder. even casa for PCV valve which is only 60,000 kms and need to be repalce.
here some quotation:
valve seal : 2450
valve guide : 1350 sets
engine valve : 650 each
head gasket: 1350 orig
camshaft oil seal: 280 each orig
PCV valve: 1200 orig
piston liner or sleeve : 1200 each plus 4000 labor for machine shop.
Ignition coil: OEM php 3500
labor:
top overhaul (or dukot).
php 4700
plus machine shops labor:
we can buy your parts or you.
3 to 5 days depending on machine shop availability
complete engine overhaul:
from valve seal piston rings, camshaft, throttle body cleaning, all gasket replace and oil ring replace
php 8500
plus machine shop labor.
5 to 8 days depend on machine shop availability.
PCV VALVE valve last only for 60,000 kms.
its only php1200.orig
the chevy optra timing is crucial if the mechanic will do it for the first time is so confusing,
and if he's not sure your engine valve get bend (550 each x 16pcs + machine shop labor +valve guide php1350)
we allready encounter bend engine valve (optra) due to timing.
php 25,000 all in all.
we do home service for your optra.
depends on how far from our shop in cainta.
txt or call us:
09164709860
for parts 50% down and 50% upon delivery.
tnx guys
lotus elise all the way! 2004 edition
Lotus returns...
