Page 3 of 12 FirstFirst 1234567 ... LastLast
Results 41 to 60 of 385
    In my limited experience, it takes a while for the tyre pressure to decrease with these tyre sensors, compared to my regular aluminum valve caps.
    Quote Originally Posted by Servus View Post
    ang purpose ng TPMS is to monitor your tire pressure real time, so no need to check it weekly kasi everytime na sasakay ka makikita mo na ang actual pressure. in my experience at least 6 months bago ko tanggalin yong sensor para maghangin. pag bumagsak na ng 28psi at cold temp don pa lang ako maghahangin.
    Well you have a point sir. If they can miniaturize the external sensors na halos kasing laki na lang siya ng takip ng pito, pwede pa.
    Konti na lang naman difference ng internal at external. Plus pa yung labor ng pag dismantle ng goma
    ^ Ok din sya bro ah. Kumpleto ang features tapos reasonably priced pa 👍
    when you look into the abyss, the abyss looks into you
    Advantage and disadvantage between internal and external sensors? Sa accuracy?
    Same lang bro.- pero, I like iyong internal (in my case- OEM) better...
    Matrabaho lang kapag nagpalit ng baterya... tanggal ang goma, kasi nasa pito... Anyway, every 3 years siguro...
    At tyre rotation,- parang iikot din ang orientation - haven't done it yet.... Sa akin okay lang,- basta may sumingaw,- check lahat ng gulong....
    Iyong external,- as I said earlier,- takaw nakaw... magnanakaw, kolektor o iyong nawalan ng kapareho....
    Dec 2007
    It'll pay for itself though we won't feel it because it's kinda preventive maintenance ang dating. 2011 I was suppose to buy a set na kaso it costs P6k. After I few months I ended up driving with a flat tire. The tire costs P5k so I'm effect, if I bought the TPMS prior to that incident, bawi na. Immediately after that incident bumili na ako. Onwards hindi na nangyari because you get to check the tire pressure everytime you drive.
    Sent from my ASUS_Z012D using Tapatalk
    May 2015
    here are the things i considered 2.5 years ago when deciding which sensor to buy.
    internal sensor advantages
    - di mananakaw unless nakawin buong tire
    - no need to remove the sensor during top up ng air
    internal sensor disadvantages
    - mahal, around 2k+ ang price difference nya for steelmate brand when i bought my tpms
    - disposable sensors since hermetically sealed sya it's not possible to replace the batt but batt life is 5 years.
    - DIY installation not possible
    - needs wheel balancing upon installation
    - hassle sa tire rotation kasi kelangan ideflate ang tire para malipat yong sensors
    external sensor advantages
    - mas mura of course
    - easy DIY installation in 10 mins
    - replaceable battery and has 3 years batt life as per manual
    - no wheel balancing needed kasi magaan lang sya
    - easy replacement when sensor get defective
    - posibleng manakaw. i don't consider it madaling manakaw kasi without the right tool masisira mo yong sensor bago matanggal
    sa accuracy same lang sila +/- 1 psi. those are the things i considered kaya i ended up buying external sensors. i don't know kung true pa ba lahat yan, didn't do any research anymore after buying it. baka malaki na improvement ngayon ng internal sensor
    Bakit kailabfan ilipat pag nag rotate ng tires? Hinde ba auromatic ma sense?
    Aug 2012
    Nope. Each sensor is marked FL, FR, RL, RR for specific tire locations.
    Sent from my ASUS_X00DDA using Tapatalk
    ^ so kapag external ang sensors, mas convenient sya kapag nag rotate ng gulong kasi mas madali sya i-set kumpara sa internal ones, that is if tire placement specific ang mga sensors nito
    That is correct bro...
    In my case, for my internal sensors/transmitters,- I do not remove them anymore even if I rotate tyres...
    I just take note where I moved them.
    Because if one becomes underinflated,- it's my warning to fill them all up....
    Finally got mine just now via lazada
    will install later and test it out
    Ayos bro. Is that the solar powered one?
    I bought another set of the same brand and model.... My recent experience in tpms, saving me a lot of time, effort and heartache made me more of a believer.... Another recent experience, it beeps of the battery voltage falls near 12v... This feature is not present with my regular voltmeter...
    Also noticed that the tyre pressure is not reduced as much using the tpms sensor/transmitter vs the regular aluminium valve caps....
    Dec 2015
    Which one do you have?
    grabe taga sa casa iyong mga cigarette lighter powered tpms sa casa.
    maski hindi oem talagang tinaasan iyong price ng almost three times na benta sa lazada and the like. dunno kung may kumakagat pa dito
    Feb 2010
    Sir, what model is your tpms with the same feature of beeping when batt volt is down? thru lazada or car accs shop? TIA
    ^ Yezzir. I bought the solar powered variety.
    So far so good naman. It's doing what it's supposed to do. Medyo napaisip lang ako sa pinagsasabi ng instruction manual kanina.[emoji16]
    And as a precaution, pinunasan ko iyong sensors ng siling labuyo para hindi mapagtripan ng mga doggos namin [emoji28]
    and yes, i'll buy another set for my fd naman. I'll purchase the kind wherein the monitor is flushed right on the dashboard blind button. Sayang naman iyong abang na switch slot na iyon kung di magagamit. I'm just waiting for the price of it to go down...if it'll ever go down.
    Dumating na din kanina.
    the instruction manual is a bit vague though. now i've just got to figure out how to make it work. 😁
    the instruction manual is a bit vague though. now i've just got to figure out how to make it work. [emoji16]
    Post ka naman Picture pag naka install na sa tires. Tingnan ko lang kung ano itsura. Pati yun Screen monitor. Thanks
    Mar 2004
    Still looking for TPMS that will display in PSI ... most in Aliexpress or Lazada use bar units ...
TPMS (Tire Pressure Monitoring System)
