Page 3 of 5 FirstFirst 12345 LastLast
Results 41 to 60 of 99
    Quote Originally Posted by alexatl19 View Post
    Papasukin daw ng tubig yung headlight na nabili ko kasi may fan daw. Yun ang sabi ng nagkakabit.
    Dumadaan kaba sa baha na kasing taas ng headlight mo?
    #42
    it doesn't have to be liquid wet.
    basta may butas or big-enough crack, puedeng higupin ang damp damp water vapor, when the headlamp cools down.
    Dec 2009
    #43
    Sa langit kaya galing ang ulan
    #44
    Reposting my foglight upgrade from cheap generic LEDs to Philips Ultinon Essential:
    The generic LEDs had weaker intensity and a dispersed beam pattern, while the Ultinon has a much clearer cutoff and stronger output.
    Note though that while the Ultinon Essential is leagues better than generic LEDs, it's still weaker than the stock LED headlamps that came with the car:
    Sep 2018
    #45
    Car lights are essential for safe driving. There are plenty of brands who provide this product in the market. But car owners should purchase depending on their vehicle. What I usually do is to search online for compatible brands for my car and look for recommendation and feedback regarding a specific brand. However, the best practice is to follow the brand recommended by your trusted mechanic to avoid any problems. It's also best to bring your car for light replacement and maintenance on your trusted car shop as they know the best for your vehicle. Hope this helps!
    Sep 2018
    #46
    May nakapagtry na ba ng c6 or hlxg? Balak ko po kasing magpalit para sa foglights.
    #47
    Yes my old generic fogs were C6. See the post above - the Ultinon has much better output.
    For aesthetics, you can't tell the difference between the C6 and Philips Ultinon bulbs - same color temp lang and since fog lamps naman hindi siya nakakasilaw. But if you look at the beam pattern, the Ultinon has a more defined cutoff, stronger output, and better foreground lighting.
    Sep 2018
    #48
    Ty sir. Siguro mag c6 na lang muna ko.
    Sep 2018
    #49
    Sa headlight naman sir. Mas okay ba yung with fan o yung fanless na LED?
    Dec 2016
    #50
    Hi All,
    Hope all is well.
    Last week, bumigay na yung foglights ko (right bulb - DLAA) and i am planning to replace the busted one with the below choices:
    1.) DK LED (catered by Jeff Tan of ACA Araneta * php 2800 - dual color, white and yellow). stress test video ng bulb nasa FB page nya - nilubog sa timba yung bulb na dual color tapos saka in-ON/OFF kasama na ballast
    challenge: unheard of this brand
    2.) Novsight LED - online seller *php3000 with 1 year warranty (super yellow)
    challenge: pricey?
    3.) Pegasus Halogen - online seller din *php700 (pair na) without install
    challenge: replacing busted bulb since mahirap dukutin sa mirage ang fog bulb.
    other than the above, baka may makakarecommend ng budget meal na fogs (H11 - super yellow)
    Thanks!
    Cheers!
    Jan 2008
    #51
    Quote Originally Posted by kamotekid1968 View Post
    Hi All,
    Hope all is well.
    challenge: pricey?
    Thanks!
    Cheers!
    Try mo sa shopee.. gzqd1686.ph seller.. meron sila dual color led.. using mine for more than a year na! Less than 1k lang pair. Fanless na yan..
    Yung C6 na gamit ko dati 1 year lang pundi lahat.. tapos maingay yung fan.
    Dec 2016
    #52
    thanks ser *yapoy86, that is duly noted...
    any other inputs mga sers sa dilemma ko? sensya na..nakakadala kasi wala pa 9 months pundi na agad yung pinakabit ko sa banawe na DLAA...tsk!
    Oct 2003
    #53
    I vouch for pegasus h11. Cheap pa.
    Jun 2013
    #54
    So I tried to fit the Novsight H1 LED I ordered. Palpak! Di nagkasya, sumasabit yung cooling fan. 😂
    I also didn’t get it to light up. Sira ata yung H1 cable adapter na nabili ko or polar sensitive lang yung cables. Hirap bunutin, naputol tuloy yung isang wire ng adapter. I’ll just sell this and buy another LED bulbs with cooling braids probably.
    Sep 2018
    #55
    Okay lang bang mag-cut dun sa dust cover ng headlight para magkasya yung nabili kong novsight. Di daw kasi kasya e.
    Sep 2018
    #56
    So I tried to fit the Novsight H1 LED I ordered. Palpak! Di nagkasya, sumasabit yung cooling fan. [emoji23]
    Parang pareho tayo ng problem sir. Novsight din nabili ko for headlight. Nung ipapakabit ko na di daw kasya parang kailangan pang mag-cut dun sa cover.
    #57
    Hi All,
    Hope all is well.
    challenge: pricey?
    Thanks!
    Cheers!
    I got my Philips Ultinon for 2.7k. Better than going for overpriced generic LEDs.
    These are 6000K LEDs though. If you want something yellow, I'd definitely suggest Osram Fogbreakers. Halogen bulbs but with strong output and good cutoff.
    Nov 2011
    #58
    Ah wow, bang for the buck yan pala.
    If I had known na 2.7k yan, I would have gone for it instead of the Pegasus LED for 2k (including shipping, DIY install).
    But it's currently doing ok naman, but with a fan that you can hear from the outside.
    So I can still recommend Pegasus, I guess.
    It has a cutoff din naman and defo not glaring.
    Bumili ka na lang ng dust cover sa Lazada.
    Jut, sa fog mo ba nilagay? Meron sila for fog and for HL, Ano difference?
Lights Compatibility Issue
