Has anybody tried it din? Tumagal ba? Mas maganda yata yung Michellin na brand http://bit.ly/2yrafY9
cant expect a cheap one to last long...
my inflator is 4yrs old and tucked inside my road emergency kit. i might need to run it so it wont dry...👀
same model below.. 27 to 33 psi.. really quickie...
black and decker asi300 air station inflator - YouTube
I have this for like 7 or 8 years na. Bought it sa Ace or Handyman for 1,500 back then. Maayos pa din maliban lang sa mejo maluwag na yung pangsaksak sa tire valve due to normal wear and tear. Mejo heavy duty din ito. Kaya tumakbo 30minutes straight.
Balak ko din bumili ng digital for convenience.
Coido 2114D
- Digital gauge
- It will turn-off once it reach your set PSI
- Relatively small compared to those heavy duty models
For me, the portable tire inflator is not worth keeping.
I once have an inflator and used it once until I thrown it away after years of keeping. Mas handy ang magpahangin sa gas station. Kung napako ang gulong, aabot yan sa pinakamalapit na vulcanizing shop o gas station.
Kapag dumapa na (very very seldom na mangyari) hindi din kaya ng portable inflator, there is a spare tire. Worn out na ang four tires, hindi ko ka nagagamit ang spare.
Been using my portable automatic digital tire inflator for several years now. Super worth it for me.
I fill up air in the morning when tires are cold at home. I do not need to go to gas station pa.
The recommended tire pressure of manufacturer is based on tire cold temperature.
"because i can. may auto-off function naman siya, e."
..."because i have to do something else". or, "because i do not want to waste my time waiting, doing nothing.""
mix myself some coffee.. forgot something in the house.. brush my teeth.. wash hands.. "the excuses are endless."
what i have, is a heavy-duty inflator. it has no auto-off function. it looks more business-like than the other sleeker, smaller inflators in the market. mine is a time-tested model. it is still as effective and fast today, as it was when new. my experience thru the years, is that cheap inflators become less and less effective, every time they are used.
Based on my personal experience, it only takes a minute to add air using my digital automatic tire inflator. So there is really no need to leave it.
But even if I leave it while adding air, it automatically stops to my preset pressure. It had never failed me ever so I don't have any issue about it. Been using this model for several years now. Tried and tested.
Sent from my ASUS_X00DDA using Tapatalk
good for you, sir.
but you see, i speak of others with significantly less discipline.
i have experienced hearing firsthand, a loud popping sound in our neighborhood. the guy forgot he was inflating his tire.
"of all the senses, common sense appears to be the least common of the senses."
I also have such inflator. I've never needed to do a tire change myself for as long as I can remember. Nakayanan din naman nung sa akin kahit dapa na ang gulong.
I was browsing the shelves of concorde a while ago and they had rows and rows of elevo inflators. Tempting din
it's a horizontal silver metal tube, with a black pressure gauge dial at the top.
no plastic body covers or any attempts at streamlining.
i have used it many times already, and it is still as efficient as when new.
it cost me 1800 bucks or so, some years back, from the mall auto accessories store.
i believe it is an "elevo" brand. but someone showed me a picture of the same, with a different name on it.
