Page 3 of 4 FirstFirst 1234 LastLast
Results 41 to 60 of 99
    Quote Originally Posted by hdj80 View Post
    Ok thats good to hear that its at least stronger than stock halogens. I was thinking of going keon sondra for my fogs since im using those for my projector headlights but spending Php 7.5k for foglight bulbs is absurd already [emoji23] ok na ako sa 2.8k petot ng philips hehe basta long lasting.
    I had a friend that got those dual color led fogs pundido na after 7 months. More expensive pa ata sa philips yan
    Ah I compared my Ultinon fogs with KS LEDs - the KS is stronger but also with more glare. Not worth 3x the price definitely.
    Sep 2018
    May nakapagtry na ba ng c6 or hlxg? Balak ko po kasing magpalit para sa foglights.
    Quote Originally Posted by alexatl19 View Post
    Yes my old generic fogs were C6. See the post above - the Ultinon has much better output.
    For aesthetics, you can't tell the difference between the C6 and Philips Ultinon bulbs - same color temp lang and since fog lamps naman hindi siya nakakasilaw. But if you look at the beam pattern, the Ultinon has a more defined cutoff, stronger output, and better foreground lighting.
    Sep 2018
    Ty sir. Siguro mag c6 na lang muna ko.
    Dec 2016
    Hi All,
    Hope all is well.
    Last week, bumigay na yung foglights ko (right bulb - DLAA) and i am planning to replace the busted one with the below choices:
    1.) DK LED (catered by Jeff Tan of ACA Araneta * php 2800 - dual color, white and yellow). stress test video ng bulb nasa FB page nya - nilubog sa timba yung bulb na dual color tapos saka in-ON/OFF kasama na ballast
    challenge: unheard of this brand
    2.) Novsight LED - online seller *php3000 with 1 year warranty (super yellow)
    challenge: pricey?
    3.) Pegasus Halogen - online seller din *php700 (pair na) without install
    challenge: replacing busted bulb since mahirap dukutin sa mirage ang fog bulb.
    other than the above, baka may makakarecommend ng budget meal na fogs (H11 - super yellow)
    Thanks!
    Cheers!
    Jan 2008
    Quote Originally Posted by kamotekid1968 View Post
    Hi All,
    Hope all is well.
    challenge: pricey?
    Thanks!
    Cheers!
    Try mo sa shopee.. gzqd1686.ph seller.. meron sila dual color led.. using mine for more than a year na! Less than 1k lang pair. Fanless na yan..
    Yung C6 na gamit ko dati 1 year lang pundi lahat.. tapos maingay yung fan.
    Dec 2016
    thanks ser *yapoy86, that is duly noted...
    any other inputs mga sers sa dilemma ko? sensya na..nakakadala kasi wala pa 9 months pundi na agad yung pinakabit ko sa banawe na DLAA...tsk!
    Hi All,
    Hope all is well.
    challenge: pricey?
    Thanks!
    Cheers!
    I got my Philips Ultinon for 2.7k. Better than going for overpriced generic LEDs.
    These are 6000K LEDs though. If you want something yellow, I'd definitely suggest Osram Fogbreakers. Halogen bulbs but with strong output and good cutoff.
    Nov 2011
    Ah wow, bang for the buck yan pala.
    If I had known na 2.7k yan, I would have gone for it instead of the Pegasus LED for 2k (including shipping, DIY install).
    But it's currently doing ok naman, but with a fan that you can hear from the outside.
    So I can still recommend Pegasus, I guess.
    It has a cutoff din naman and defo not glaring.
    Jut, sa fog mo ba nilagay? Meron sila for fog and for HL, Ano difference?
    Sep 2018
    Sa headlight naman sir. Mas okay ba yung with fan o yung fanless na LED?
    Sep 2018
    Okay lang bang mag-cut dun sa dust cover ng headlight para magkasya yung nabili kong novsight. Di daw kasi kasya e.
    Bumili ka na lang ng dust cover sa Lazada.
    Cutoff of the Ultinon fogs.
    Jun 2013
    Tanong ko nga pala, how much do you use your foglights? Bakit humina agad yung generic LED? Planning on buying from an unknown brand for my high beam.
    Sea Bloom:2PCS S7 H1 LED Car Headlight 6W Front Light Bulb 64LM 6K Auto Headlamp | Lazada Singapore
    Anybody tried this S7 LED? Ito lang kasi nakita kong H1 na braided yung cooling system.
    1 year's worth of driving, 15,000 km. I have it on when I drive at night, an average of 1-2 hrs daily.
    In comparison, the HIDs on my Mazda 3 lasted 2.5 years, while the HID fogs on our CRV lasted 1.5 years. Both retrofitted, by Tots and Gary, respectively.
    Let's see how long these LEDs last.
    Aug 2009
    How much was the bulb replacement on your CRV?
    Quote Originally Posted by Sleepcare View Post
    3.5k IIRC.
    Dec 2009
    ^that's not safe..led may look better but your demo simply compromise safety over form which is not good for an engineering point of view
    Jun 2013
    I guess so. Wala na kasi ibang magkasya na LED sa high beam. Sobrang sikip sa housing. Maganda sana branded pero wala eh... I’ll have to test it further. Napansin ko mas umiilaw mga reflector sa malayo pag LED but those without reflectors like pedestrians, di mo masyado makita sa malayo.
    Yung low beam ko philips ultinon, ang ganda, definite upgrade sa halogen. Guess it’s different for the high beam.
Lights Compatibility Issue
