Page 2 of 5 FirstFirst 12345 LastLast
Results 21 to 40 of 99
    #21
    ^an enlightened individual based on experience (from halogen to led then back to halogen)
    I dont led for the form of its look nor the power saving but from the science behind light which made me stick to halogen and never switched to led
    You, brother, are the enlightened 1, whilst hobo here was the moth drawn to the fire, got burnt.[emoji4]
    In the guinea world, experiments can succeed or fail...the latter always more memorable.[emoji4]
    #22
    folks should recognize the difference between announcing ones' presence, and blinding them with their radiance.
    the true test of glare, is to stand in front of, and face one's vehicle, and "see for oneself".
    the un-controlled light from halogens is weaker than those from leds. glare from halogens may be forgive-able, while the stronger glare from leds may not be forgive-able.
    in some cases, one wouldn't have to upgrade, if one simply removed the front windshield tint.
    my thoughts.
    Amen[emoji120][emoji4]
    Jun 2013
    #23
    my thoughts.
    I actually did that exact test! 😂
    I did it with the halogen and I also did it with the LED. It didn't blind me at all. And all incoming cars never flashed their high beams. The cut off of the philips ultinon essential is really good but it is the weakest LED out of all their philips LED line up. However it is definitely brighter than stock halogen plus the white light is more noticeable during night.
    With the misting of headlights, I haven't experienced it in all our cars. So it is really not an issue. Yung taillights pa dati ng vios namin pinapasok ng tubig but never had those inside the headlights.
    Sep 2018
    #24
    Tanong ko lang po kung anong led headlight yung magandang klase? Tsaka po yung maliwanag? Honda city 2012
    Jun 2013
    #25
    Quote Originally Posted by alexatl19 View Post
    Check mo reviews ng Philips Ultinon xtreme H4.
    #26
    My LED fog lights are beginning to fail, with the right light being much weaker than the left.
    I think I got my money's worth anyway - these cheap generic bulbs cost 350 pesos and lasted exactly a year.
    Now contemplating if I should get another set of generic bulbs or just go for the much more expensive Philips Ultinon Essential at 3.5k (10x a generic bulb).
    For sure the Philips will last longer, but I doubt it'll last 10x longer (i.e. 10 years).
    Sep 2018
    #27
    Ok po ba yung novsight na led para sa headlight?
    #28
    If bent on LEDs, stick w/ the recommended Philips above. Most of what's out there are hit/miss.
    If just looking for brighter halogens, check Philips XtremeVision.
    #29
    Don't wanna go yellow Osram FogBreaker or Philips WeatherVision halogens, sir?
    Jun 2013
    #30
    Meron tag 2.6k sa shopee na authentic.
    Sep 2019
    #31
    Anong brand ang binibili nyo para sa H1, H3, H4 bulb?
    Maganda ba bosch?
    Ok na yan. Sobrang muna na nga nyan brand na yan nagaalanganng ka pa.
    Try mo kahit mapundi yan in 1 year sulit na rin
    Jun 2013
    #33
    Baka hindi ok ang cut off tulad ng Philips. But I am planning on buying novsight for the high beam because it will not be turned on as much as the low beam...
    Ok cutoff. Hinde nakakasilaw
    Jun 2013
    #35
    Have you tried novsight sir? Totoo ba talaga yung lumen rating nila? Planning on buying their N13 H1 bulb... pero I wonder how true is their 8000 lumens per bulb... 🤔
    Have you tried novsight sir? Totoo ba talaga yung lumen rating nila? Planning on buying their N13 H1 bulb... pero I wonder how true is their 8000 lumens per bulb... [emoji848]
    Yes, ano ba headlights mo? Projector or reflectorized?
    Jun 2013
    #37
    Reflector both low and high beam. Naka philips ultinon na ako sa low beam. Gusto ko mas mura pero ok ang buga ng ilaw sa high beam kasi di naman issue ang longevity, minsan lang gamitin.
    #38
    Had the Fogbreaker na before. Prefer the aesthetics of white LED headlamps and fogs. Have also tested it in provincial driving and inclement weather (including the notorious fogs of Sagada) and the higher intensity of the LEDs still perform better than yellow halogen fogs.
    Thanks for the heads up, much cheaper nga than Lazada. Will probably just get that to give it a try.
    Sep 2018
    #39
    I just ordered novsight n11 h4 from shopee.
    Sep 2018
    #40
    Papasukin daw ng tubig yung headlight na nabili ko kasi may fan daw. Yun ang sabi ng nagkakabit.
Lights Compatibility Issue
