Page 5 of 17 FirstFirst 12345678915 ... LastLast
Results 81 to 100 of 337
    Oct 2009
    #81
    i bought the force alarm last saturday from sir jameson. maganda yung alarm based on my needs.
    ito napansin ko sa alarm:
    • medyo nahihinaan ako sa siren, pero pwede naman palitan yun ng ibang siren.
    • di ko ma-configure yung password change setup. sinunod ko naman yung nasa manual na "9x gagawin", pero mukhang ayaw. meron na po ba nakapag-change ng password?
    • mukhang nadi-disable yung alarm module pag umaandar na yung kotse, kasi tinry ko i-lock yung kotse while the engine is running, pero ayaw. yung dati kong alarm, pwede yung ganun. useful kasi ito minsan pag madalian lang yung pagbaba (i.e. daan sa cr ng gasoline station) para di na papatayin yung engine. di ko lang sure kung out of scope ito nung force alarm or pwede magawan ng paraaan
    *marvinix: meron po syang shock sensor, merong knob na maliit yun. afaik, dapat kinabit yun sa isang matigas na part ng kotse mo (i.e. chassis). most likely nasa area yun sa ilalim ng driver side dashboard
    *otep: i like the way you recommend the force alarm, and the electrician you suggested. ok na ok po si sir jameson. many thanks for the recommendation
    Dec 2007
    #82
    Installed the Force Alarm kanina lang. The whole thing lasted from I think 10am hanggang 5:30 Not in the negative way, pasaway lang ang auto ko.
    The alarm costed me 1700 pesos. Not bad. Masaya na ako. with 300 petot labor. Dinalahan ko ng breakfast si Jameson kasi baka di pa kumakain umagang umaga dinistorbo ko. Overall cost is 6000 kanina. 4000 lang dala ko pera babalik ko bukas yung 2000. Madaling kausap si Jameson highly recommended.
    I will post yung mga pinagawa ko sa auto as reference to our fellow tsikoteers.
    Force Alarm: 1700 pesos
    Installation: 300 pesos
    Diode para sa signal light yung light ng alarm: 150 pesos
    Stebel Magnum horn: 650 pesos
    Installation: 100 pesos
    My central lock is not working and so is my power mirrors. Nag submarine kasi ang kotse ko noong bagyong Ondoy, mga kalahating tao pa above the roof ang tubig. At nababad dun for 6 hours. Na asikaso ko lang ang auto after 3 days, dun ko lang na disconnect ang battery.
    Repair of the motor locks sa pinto: 300 each door. 5 door ang tsikot ko, sabi ko 1,200 na lang okay naman. Na stock up kasi ang motor ng power lock ko.
    Module for the power lock, 650. Yung utak lang ang kinuha, babalikan ko ang galamay bukas.
    Repair of the stock up motor sa power mirror: 800 for the pair.
    Repair of the naglolokong fog light, nilagyan ng relay and wiring, 500.
    Nabitin pera ko eh ibabalik ko na lang bukas.
    Overall, happy ako. Tigbak ang kotse ko eh, estimate sa casa is 50k conservative, wala pang parts na papalitan yung comp box lang. 10k pa lang nagagastos ko gumagana na lahat except the EPS. Happy ako nag ka power locks ako, nag ka sensor alarm pa. Happy rin ako gumagana na power mirrors ko at ang fog lights di na nagloloko.
    #83
    Iba ata yung gumagawa ng EPS pero kakilala din nila. I also recommended his services to my friend who submarined a Nissan Xtrail last Ondoy.
    Oct 2009
    #84
    Boss OTEP pagamit nadin po ng pangalan mo pagkontak ko kay jameson. Nagloloko na din kasi yung cobra alarm ko and need replacement na. If ever, may iba pa ba na pwedeng ikabit si jameson na alarm aside from Force? TIA!
    Dec 2007
    #85
    Bro grifter nag-i-install si Jameson ng kahit anong alarm. Nag tanong nga ako ng viper sa kanya worth 4,500 pero sabi ko as to function ano pinag kaiba, same lang din naman.
    Doc Otep - meron dun lumapit sakin yun kasama nila na gumagawa ng ECU box for 15k. Buti yung box ko ayos kahit submerged for a long time. Singil niya sakin for the EPS is 7.5k. Medyo di pa kasi ako nakakapag canvass at baka bumigay din kasi pag hininang niya ulit. Tanong tanong muna ako sa Toyota.
    #86
    I usually just bring anything electronic to his stall to have it installed. Including lights, emergency equipment, etc.
    He's also good with audio systems but if you want a tuned box, siguro bring your own box na lang. hehehe. They do have and can make basic box designs, though.
    He can work on everything from a '48 Ford to my dad's R107 SLK.
    He's also the only guy I know that can disarm and remove an airbag equipped steering wheel using basic tools.
    Nov 2007
    #87
    ayaw talagang mag-alarm sakin if nakaopen harap na pinto then I press ARM sa remote. whatcha think guys pwede ba itong i-DIY or balik na lang ako kay jameson? pasay pa kase ako galing eh. anyways, itext ko rin sha tom baka pwedeng ako na lang..
    Oct 2009
    #88
    Quote Originally Posted by nurse_corrupted View Post
    thanks bro nurse_corrupted, dun ko na nga lang dalhin kotse ko. hirap ng basta basta na lang na electrician. thanks thanks!
    #89
    mga sir pwede rin po ba silent arm and disarm force alarm or talagang may chirp sound sya everytime activate and deactivate.. thanks..
    #90
    Quote Originally Posted by speed_pjay View Post
    Actually, this is possible.
    I recall reading this in the manual somewhere though I have yet to use that particular function.
    Looks like I have to go over it again.
    #91
    Quote Originally Posted by HardCharger View Post
    thanks sir, mas gamit ko kasi yung silent arm and disarm.. mas gusto ko po kasi yung magtrigger lang yung sound if nabuksan yung door.. nakakairita kasi yung may dumaan lang tunog na ng tunog.. hehe..
    by the way sir, pwede po ba ito ikabit sa '07 isuzu sportivo? nalubog po kasi sa baha yung auto namin and sira yung alarm system module.. as per isuzu tech advice hindi sila familiar kung pwede yung ibang after market alarm system kasi meron ata naka-program yung OEM sa engine ignition system.. super mahal naman po yung module sa kanila.. rough estimate is P14k... thanks..
    #92
    Pwede iyan sa Crosswind. Walang problem.
    #93
    ok thanks doc, daan nalang ako kay sir jameson pag-maaga na release sa isuzu tomorrow yung vehicle..
    Aug 2008
    #94
    Quote Originally Posted by yomar View Post
    To those interested, I have a PDF version of the owner's manual of this alarm system. PM me if you would like to read it first before buying.
    Can you email the owner's manual? Thanks.
    Last edited by aysiyadi; October 31st, 2009 at 04:11 PM. Reason: already have the information
    #95
    Hi,
    New here in this forum,, pero matagal na po ako nagbabasa,,,
    *doc otep, question po sir,, yung number po ba ni Jameson yun pa rin?? kasi po im planning to have a new alarm for my car,, kasi yung luma kong alarm sabi nung electrician na pinagawaan ko kung saan saan daw naka tap e,, e sira na rin yung remote ko kaya plano ko na lang kumuha ng bago,,
    saka isa pa pong tanong,, ano po magandang alarm na marerecommend nyo??
    #96
    hahaha nakita ko na po bagong number ni Jameson,, hahah may sarili syang thread! hehehehe salamat doc otep!
    Sep 2008
    #97
    hello guys.
    i have a stock alarm sa benz '85 ko, chassis 124. stock nya is yugn clifford na alarm. tagal na eh. so im planning to change it into FORCE. kasi yung stock SS ko eh parang sira na. hindi na minsan gumagana yung remote kay gamit ko ang key to open. pwede po ba ang FORCE sa ride ko? vacuum po yung gamit eh. medyu mahirap daw sabi ng iba. and one more thing, wala ako makita na FORCE dito sa iloilo, GIORDON lang at COBRA ang makita ko. ok po ba yan? need pa ba ipalit ang powerlock? or module, siren na lang at yung something na nag lalight up(hindi ko alam ang name, hehe) at keys.
    and if i install an new SS, automatic na ba na mag ilaw ang signal lights when i lock/unlock the doors? kasi ngayun hindi na gumagana eh.
    #98
    My dad has a W124 with vacuum locks. Pero hindi ata sina Jameson ang gumawa ng security system niya for that particular ride (tagal na yung SS, old school Viper).
    Signal light confirmation is by request (with minimal added cost). Otherwise, visual confirmation is via the park lamps.
    Sep 2008
    #99
    how will i know if that particular SS is compatible for my car? vacuum locks
    #100
    installer dependent po. any brand works basta marunong magkakabit
Budget Special: FORCE Vehicle Security System
